ᐅ Difference between KALLAX and EXPEDIT – is it really just about appearance?
Created on: 19 Aug 2024 14:07
luge38
luge38
19 Aug 2024 14:07
I am currently considering whether to buy a KALLAX or an EXPEDIT shelving unit from IKEA for my living room. I have often noticed in discussions that people say the difference is "just the appearance." Therefore, my question is:
Aside from the visual design and color options, are there actually no functional or structural differences between the KALLAX and the EXPEDIT?
I am particularly interested in aspects such as material quality, stability, load capacity, dimensions, improved manufacturing, or compatibility with accessories like drawers, doors, and inserts.
Does anyone have practical experience or even technical data on the differences? Or is this really just a matter of design?
Thanks in advance for your feedback!
Filippo
19 Aug 2024 16:44
Hello luge38,
That's a very interesting question you’re asking. Often, discussions focus only on the appearance, but when you look more closely, there are indeed differences that go beyond just the design.
First of all: EXPEDIT was the older model that IKEA sold for several years before it was replaced by KALLAX. KALLAX is basically the modern development of that design. You can notice this, among other things, in the material quality:
EXPEDIT often had somewhat thicker panels, although the manufacturing was not always consistent, which sometimes led to slight quality variations. KALLAX generally uses slightly thinner panels, but these are better processed with an improved surface that is more resistant to scratches and moisture.
There have also been changes in the construction: for example, the back panels on KALLAX are attached more securely and sometimes include additional reinforcements. This makes the entire shelf sturdier, even when it’s larger or more elaborately arranged. The dimensions are almost identical, with KALLAX being a few millimeters (inches) taller and wider, but nothing that significantly alters usability. The internal measurements remain nearly the same, meaning that accessories from EXPEDIT usually also fit KALLAX.
Another point: KALLAX was better designed for modular extensions and accessories. Many drawers, boxes, and doors have been redesigned and overall feel more harmonious and stable. The fastening options for doors and dividers are more cleverly engineered, making handling easier and safer.
I’m curious to know what you primarily plan to use the shelf for? Are you intending to put heavy loads on it, such as heavy books or equipment, or is it more for decoration and lighter items?
That could make a difference as to whether you prioritize stability or appearance.
Maria35
20 Aug 2024 09:22
In addition to Filippo’s comments, I would like to add some more precise facts:
1. Load Capacity: According to official IKEA information, the maximum load capacity of individual KALLAX compartments is about 13 kg (29 lbs), similar to the former EXPEDIT. This capacity is sufficient for most uses, but there are reports that KALLAX feels more stable due to its optimized design.
2. Dimensions: KALLAX shelves are compatible with EXPEDIT in standard sizes and depths; however, the surface treatment has been improved in KALLAX (laminated edges, better sealing).
3. Accessories: While most EXPEDIT accessories are compatible with KALLAX, IKEA has expanded and made the product range more user-friendly with the new version, simplifying assembly.
4. Environmental Features: KALLAX is now produced with a higher proportion of recycled materials, which is positive in terms of modern sustainability standards.
Conclusion: The differences are not only aesthetic. KALLAX represents a technical advancement with improved workmanship and user-friendliness, which can be noticed in the details.
In my opinion, these differences are especially relevant for users who value stability, durability, and environmental considerations.
TEOZAR
21 Aug 2024 07:59
That’s exactly right – KALLAX was introduced in 2014 as the successor to EXPEDIT. The design was modernized and the construction improved.
Maria35 schrieb:
KALLAX is now made with a higher proportion of recycled material
Definitely an important point. Besides the manufacturing process, sustainability was a key focus.
Additionally, I learned from a furniture retailer that KALLAX is overall lighter, which makes transportation easier. For the end user, this means more flexibility. Apart from the appearance, you’ll also find functional and handling improvements with KALLAX.
One tip: If you want to use the shelving unit for heavy loads like books or electronics, be sure to check the box joints—even though KALLAX is sturdier, it’s not designed for industrial-level loads.
I’d love to know: What kind of accessories are you considering? Doors, drawers, or maybe special inserts?
