Lukas453627 Aug 2022 16:20Good day,
I am currently planning a new heating system in North Rhine-Westphalia and have received several quotes.
At the moment, a gas heating system is in use, which will soon need to be replaced. The plan is to replace it with a heat pump.
The heat distribution system is underfloor heating covering 190 m² (2,045 sq ft) over two levels, and radiator heating for an outbuilding of about 40 m² (430 sq ft), which is usually only heated minimally (maintained between approximately 4 and 8°C (39°F to 46°F) during winter).
Additionally, a photovoltaic system of around 10 kWp, with the option to expand in the future, will be installed.
Currently, I have the following five estimates, which differ greatly both technically and in price.
(All prices include VAT.)
As a layperson, I naturally have little knowledge in this area and would appreciate advice on which offer is reasonable.
Furthermore, the various proposed heat pumps use different refrigerants: What should I pay attention to in this regard?
And more generally: What would you recommend?
Which brand is considered the best? Are there any that you would advise against?
Lukas
1) Chofu with 16 kW (18,000 €)
(Installable this year)
CHOFU monoblock heat pump 16 kW
Refrigerant: R32
Switching valve
35 m (115 ft) piping
35 mm (1.4 inch) fittings
Including connection materials and installation
2) Bosch with 14.8 kW (26,400 €)
(Installable next January)
BOSCH split heat pump SAS 13-2 ASE, 14.8 kW, monovalent
Refrigerant: R410A
2x BOSCH remote controls/room controllers CR 10 H
BOSCH refrigerant lines SAS 3/8" and 5/8"
Wall mounting brackets for air/water heat pump
JUNKERS hot water switching valve 22-1 for heat pumps
Membrane expansion tank 25 l (6.6 gallons), silver, max. 3 bar
FLAMCO Flexcon suspension frame type MB 3
Logafix cap ball valve MK 3/4"
XStream vent-clean (DN20) K22
Pump group UK 1", without pump
Pump group MK 1", without pump
BOSCH mixing module MM 200 for 2 heating circuits
2x Grundfos circulation pumps Alpha1 25-60 180230V
2x Grundfos Alpha right-angle plugs, 4 m (13 ft) cable
Distributor bar for up to 3 heating circuits
BWT storage connection set 3/4" M KS 1267-34 M with 6 bar safety valve
Various pipes, fittings, and connectors
System filling according to ÖNORM
Work time: installation and connection of heat pump including accessories
Commissioning by factory service
3) IDM with 10 to 24 kW (45,000 €)
(Installable next March)
IDM AERO ALM heat pump 10-24 kW, modulating
Accessories AERO AL 10-24 (buffer tank, etc.)
Refrigerant: R290
3 x large-surface radiators
Various materials
Commissioning
Underfloor heating manifold
Small materials
Work time
4) IDM with 8 to 17 kW (30,000 €)
(Installable next December)
IDM AERO SLM heat pump 6-17 kW, with NAVIGATOR 2.0
Equipment variant HGL
Refrigerant: R410A
Commissioning
Room unit for one heating circuit to NAVIGATOR
EIB-KNX module
Air separator
Magnetic sludge separator
Refrigerant connection lines, length 5 m (16 ft)
Distributor for underfloor heating
5) Saunier Duval with 12 kW (25,000 €)
(Installable this October)
Saunier Duval heat pump with 12 kW
Refrigerant: R410A
Various materials
Commissioning
Work time
Lukas
Refrigerant: R32
Switching valve
Refrigerant: R410A
Refrigerant: R290
Various materials
Commissioning
Small materials
Work time
Refrigerant: R410A
Commissioning
EIB-KNX module
Air separator
Refrigerant: R410A
Various materials
Commissioning
Work time
Lukas453627 Aug 2022 17:45I cannot provide specific insulation values, except that the walls are very thick, there is a thick layer of expanded polystyrene (EPS) insulation on the exterior, the intermediate ceiling is thicker than usual, and the windows are triple-glazed.
So far, the heating load calculations for the heat pump have always resulted in values between 12 and 17 kW.
Lukas453627 Aug 2022 17:49Just for your information:
The current consumption is about 46,000 kWh of gas. However, this is also due to an old, inefficient, and poorly adjusted gas boiler. Everyone has told me that I should be able to manage with around 32,000 kWh.
The photovoltaic system currently does not have a battery storage.
The underfloor heating only requires a supply temperature of about 40 degrees Celsius (104°F). The hot water tank (possibly via a buffer tank) is also supposed to be heated by the heat pump.
There are no other heating sources at this time.
