praulric309 Feb 2023 08:34Hello everyone, I would like to cut my Billy shelves to custom sizes myself because I want to use them more flexibly and not be limited to the standard dimensions. My question is: What are the best tips and tricks for cutting the shelves precisely? Which tools are most suitable, what materials should I consider, and how can I finish the wood so that the cut shelves look stable and neat? Additionally, I would like to know the best ways to protect or refine the edges, especially since the shelves are usually made of particleboard. Thanks in advance!
A sensible starting point for your project, praulric30. For cutting Billy shelving boards, I recommend using a table saw or a jigsaw with a fine-toothed wood blade to ensure clean cuts. Keep in mind that the shelves are usually made of coated particleboard, which can splinter when cut. Therefore, it is advisable to apply painter’s tape along the cutting line beforehand, as this significantly reduces splintering. After cutting, it is recommended to finish the edges with a fine edge, such as an edge protector profile or edge banding, to provide additional stability and protection against moisture.
I would like to add a simple step-by-step guide to help with cutting the Billy shelves:
1. First, measure carefully and draw a clear cutting line with a sharpened pencil.
2. Apply painter’s tape over this line to prevent the veneer layer from chipping during sawing.
3. Use a fine-toothed jigsaw or a table saw with a guide rail to make the cut as straight and clean as possible.
4. After cutting, lightly deburr the edges with sandpaper (grit 180-240).
5. Finally, press on edge banding stickers or apply them with an iron – this protects against moisture and gives a professional finish.
6. For a more high-quality look, you can seal the edges with matching paint or clear varnish. Always make sure not to work on the panels when they are too wet.
It’s interesting how some people make cutting so complicated. Honestly, you can easily cut the shelves to the right size using a handsaw – most people do it like that without much effort. So why use so much equipment and preparation? Painter’s tape and edge protectors seem a bit excessive for a piece of furniture that isn’t load-bearing anyway due to its design. Unless you’re a professional woodworker, a clean handsaw and some fine sandpaper for smoothing usually do the job. I’d say all that extra effort is only worth it if you want a perfect finish; otherwise, it’s just a waste of time.
karlau schrieb:
To be honest, you can just cut the shelves to size with a handsawI find this view problematic when considering accuracy and durability. Billy shelves are usually made from particleboard coated with melamine resin, which can chip or fray if cut improperly. This quickly leads to rough edges and reduces the stability of the shelving unit. Additionally, a precise tool like a table saw can deliver much more even results, benefiting both the structure and appearance. In my experience, simple handsaws are not sufficient if a professional or at least clean finish is desired.
praulric309 Feb 2023 14:02Thanks in advance for the detailed answers and the discussion! One more question for clarification: How exactly should you work with painter’s tape? Should it simply be applied over the cut line and then cut through with the saw? Or does it need to be carefully removed before continuing? I want to prevent the coating from chipping during the cutting process, but at the same time avoid any adhesive residue or unsightly marks on the surface. Also, I would be interested to know if there are special edge bandings that can be applied with a regular household iron, or if it’s better to use professional tools for this.
