I recently assembled an IKEA METOD kitchen and am facing the challenge of fitting the baseboards neatly and without unsightly gaps on a slightly uneven floor. The floor panel is not completely flat, which causes the baseboards either not to sit flush in some areas or to create unwanted gaps in others. My question is: What is the best way to install the IKEA METOD baseboards when the floor is not perfectly level, to ensure a visually pleasing, clean, and stable fit? Are there any specific techniques, adjustments, or additional materials that have proven effective? I want to avoid having to rework the baseboards later or having them become loose.
Short and sweet, with a wink: If your floor is so uneven that the baseboards seem to want to find their own path, that’s exactly the chance to become a little DIY artist! 😉
My tip: Flexible plastic wedges or thin felt pads work great to close the gaps while protecting the baseboards. It might sound strange, but a bit of finesse when clicking them into place really makes a difference.
Takutau schrieb:
The Metod baseboards are usually snapped into place. Make sure the clip mechanism is not blocked by any underlay.This is an important note. I was considering fixing the baseboards simply with adhesive foam or something similar to level out unevenness. Could that permanently block or even damage the clip? Are there alternatives if you want to keep the secure snap connection?
The trick with uneven floors is to level everything as invisibly as possible. Make it a small DIY project using fine sandpaper and wooden shims cut to millimeter precision. 🎨 It may sound like a lot of effort, but a neat baseboard without annoying gaps simply makes your home feel much more comfortable. Small irregularities are the enemy you need to tame!
nonpra schrieb:
Flat wooden spacers are better because they don’t interfere with the click mechanism. This way, the functionality is preserved, and you can compensate for unevenness. Thanks for the tip, I will try it that way.
I’m still wondering: How do you then attach the spacers to the floor? Just place them loosely or fix them with adhesive? I’d like to stay flexible in case I want to make adjustments later.
I would recommend positioning the spacers loosely first and temporarily attaching the baseboard to check the fit. If everything fits well, you can secure the spacers with small drops of construction adhesive – this will hold firmly but still allow you to remove them later with some force. This way, you get the perfect balance between stability and flexibility.
Also, make sure the spacers are not too thick; otherwise, the baseboards won’t snap in smoothly.
