ᐅ How do I attach Ikea Metod kickboards to unusual floor coverings?
Created on: 23 Sep 2024 08:17
nonklo
I am currently planning the installation of the Ikea Metod baseboards in my new kitchen but am facing a challenge due to a very unusual flooring type. It is a thermally insulated cork floor with a rather uneven surface and a flexible subfloor.
My main question is: How can I securely attach the Ikea Metod baseboards to such an unusual floor covering so that they hold permanently without causing any damage to the floor?
Standard nails or screws don’t seem ideal here because the floor is softer, and I want to avoid compromising the insulation layer. Are there any proven methods, special fasteners, or alternative solutions you could recommend?
I would greatly appreciate any tips on surface preparation, adapting the baseboards, or experiences with other soft or uneven floors. Thanks in advance!
gasidney
23 Sep 2024 11:23
If the ground is soft, screws usually go through. So use adhesive and attach to the wall. Possibly mount clips on the wall, then clip the molding into place.
nonklo
24 Sep 2024 07:54
GiRoyce schrieb:
I would recommend the following:
- Instead of nails or screws, use a strong adhesive suitable for flexible substrates. Hybrid adhesives based on MS polymer are ideal; they bond very well and remain elastic.
- Make sure to thoroughly clean and dust the cork flooring beforehand to ensure optimal adhesion of the glue.
- If the baseboards are very long, you can additionally install small washers or spacer blocks on the wall to reduce pressure on the floor.
- Check the instructions from Ikea, as they often offer clips for fastening – here, it should be verified whether the clips can be easily combined with the adhesive.
Thanks, GiRoyce, that’s very helpful. I’m still wondering if I can use the clips even when gluing the baseboards, or if that would be counterproductive?
And what about removal later on, if renovations are needed? Is removing glued baseboards from cork flooring particularly problematic?
tra_nina
24 Sep 2024 08:37
nonklo schrieb:
I’m still wondering whether I can use the clips if I glue the baseboards, or if that would be counterproductive?
If you glue the baseboards, using clips in addition usually doesn’t make much sense, as the board is fixed by the adhesive surface. Clips are primarily intended for mechanical fastening on solid substrates.
Regarding removal: Glued baseboards can be taken off, but this may damage the cork flooring. It is recommended to place a thin separating film or some painter’s tape under the board before gluing to minimize damage. Alternatively, use adhesive that can be released with heat.
In general, for cork floors, bonding should be done as gently and reversibly as possible.
GiRoyce
24 Sep 2024 09:09
nonklo schrieb:
I’m still wondering if I can use the clips even if I glue the moldings, or if that would be counterproductive?
This combination is actually quite uncommon. Clips are meant to make the moldings removable, which isn’t the case when you glue them. If you plan to remove the moldings frequently in the future, clips are more suitable. If the bond is meant to be permanent, glue alone is sufficient.
nonklo schrieb:
And what about removal later on if renovations are needed?
Glue can damage the cork surface when removed. To reduce this risk, you can take the following steps:
- Use adhesive that is not overly strong or can be softened with heat.
- A thin separating layer (e.g., very thin tape) under the molding before gluing can help make removal easier.
If easy removal is important to you, self-adhesive clips or mechanical fixings attached to the wall with some clearance above the floor would be a better choice.
dijan
24 Sep 2024 09:52
It sounds like you need an elegant solution that also takes the floor installation into account.
Maybe you can install the baseboards so they are fixed to the wall but only rest lightly on the floor or are minimally glued. This way, the floor won’t be stressed, and you can better accommodate any unevenness.
If you’re up for a small experiment: I installed flexible baseboards on my cork floor using hook-and-loop tape to attach them to the wall and the baseboard – it holds well, can be removed easily, and protects the floor. I’m not sure if it’s right for you, but maybe it’s a helpful idea.
KNUTGI
25 Sep 2024 07:23
dijan schrieb:
I installed flexible baseboards on my cork flooring, which are attached to the wall and trim with hook-and-loop tape – they hold well, can be removed easily, and protect the floor.
That sounds great! Flexible and reversible, exactly what you need on such a soft floor. Hook-and-loop tape makes it possible and even holds up well against minor vibrations.
I think solutions like this show that you can achieve very creative and floor-friendly fixings even with unusual floor coverings!
Wishing you continued success, nonklo!
