ᐅ Children climbing on Kallax shelves – how to secure them safely?
Created on: 23 Mar 2024 11:37
leotar39
leotar39
23 Mar 2024 11:37
I have a typical Kallax shelving unit from IKEA at home, which my child often uses as a climbing frame. I understand that these shelves are not intended as play equipment, but children naturally find it exciting and like to stand on top or climb into the compartments.
My question is: How can you best secure children when they climb on a Kallax shelving unit to prevent injuries?
I am especially interested in practical everyday solutions: For example, is it necessary to always surround it with cushions or mats, or are there simpler ways to reduce the risk of a fall? How have you dealt with it if the child continues to climb on the Kallax despite repeated warnings?
I try to realistically assess the dangers, but any ideas for improving safety and accident prevention are very welcome. Thanks in advance for your support!
U
usbla
23 Mar 2024 14:29
For better safety with children climbing on Kallax shelves, I recommend a combination of physical safety measures and behavioral rules.
First: Padding such as foam or yoga mats around the shelves can cushion falls. The mats should be as non-slip as possible and cover the entire floor area around the shelves to protect potential fall zones.
Second: The furniture should be securely anchored to the wall to prevent tipping — an important factor, as climbing children often pull on or lean against the shelves.
Third: Children should be clearly taught that Kallax is not a play or climbing structure. This can be reinforced through consistent, repeated instructions and especially by providing alternatives, such as a proper climbing wall or outdoor climbing frame.
The problem is that safety measures alone can never completely eliminate the risk. Therefore, I would recommend teaching children at an early age to handle furniture responsibly.
Surela
24 Mar 2024 09:05
The question of securing children who climb on Kallax shelves requires a nuanced approach. Several factors are involved, including the child’s age, the height of the shelf, the flooring, and the children’s behavior.
usbla schrieb:
The furniture should be securely anchored to the wall to prevent tipping over
This is definitely a must. Due to the construction design of Kallax shelves, their stability is limited, especially when children hang or climb on them. Professional wall anchoring is essential to minimize the risk of tipping.
leotar39 schrieb:
How did you handle it when the child did not stop despite repeated warnings?
Here, it is important to act preventively: I recommend establishing direct supervision while also providing alternatives. A low, sturdily built play furniture item — such as a well-known indoor climbing tower or a small climbing wall — reduces climbing on the furniture itself.
Technically, you can also add corner protectors on the furniture edges to reduce injury risks. Rubber or foam profiles are helpful here.
Regarding floor protection: between padding and mats, it is advisable to use impact-absorbing mats like those used in climbing gyms. These are thicker and absorb shocks better.
You might also consider relocating the furniture to create a larger, padded fall zone.
mauka
25 Mar 2024 17:42
The Kallax shelf is kind of a classic magnet for kids climbing on it—you often see little climbers up there, and it was no different for us. Still, I believe you can handle this with some humor and proper protection. :-)
In our experience, placing thick gymnastics mats on top of the shelf works well. We use mats meant for yoga or gymnastics. They are non-slip and fairly easy to store when not in use. This way, if a child falls, at least there’s a soft surface underneath.
Surela schrieb:
Creating alternatives: a sturdy indoor climbing tower or a small climbing wall
I totally agree with that! Offering kids an alternative place to satisfy their urge to climb can be much more effective than just forbidding it. Sometimes you just have to play along and show mutual understanding.
And yes, securing the shelf firmly to the wall is extremely important. Also, make sure any nearby electrical outlets are childproofed if they’re exposed. I think with a bit of preparation, the climbing adventure on the Kallax can become safer and even fun. 😉
What do you think? Does anyone have DIY tips on how to make inexpensive small impact-absorbing pads?
