ᐅ Are there carpet underlays that prevent wobbling for tall Kallax shelving units?
Created on: 22 Oct 2016 18:03
buronHello everyone, I have a small problem with my new Kallax shelving unit: the tall arrangement wobbles slightly when I pull or push the lower shelf. I have been thinking about placing the shelf on a carpet underlay to improve stability. My question is whether there are specific carpet underlays or anti-tip devices designed especially for tall Kallax units? It’s important to me that they are not too thick and that the furniture remains secure and stable despite being on carpet – maybe there are some clever solutions or recommendations? Looking forward to your experiences and tips!
Wobbling in tall Kallax units is often caused by a combination of uneven floors and the shelf’s own design. Before focusing on carpet underlays, check if the unit stands completely flat. If not, small adjustable furniture glides are a good solution.
If the floor beneath the carpet is uneven, a thin non-slip mat with slight cushioning improves stability and reduces wobbling. There are no special "anti-tip carpet pads" made specifically for Kallax, but non-slip carpet underlays work well.
Tip: Avoid mats that are too thick, as they can make the shelf unstable. Attaching the unit to the wall may also completely prevent tipping.
umberto schrieb:
Carpet underlays help prevent slipping, but not wobbling.That's true, but apart from securing to the wall, these narrow anti-slip mats actually work wonders. They cushion minor floor unevenness and vibrations, so while the wobbling is at least reduced—the shelf won’t be completely stable—it’s overall more comfortable. 🙂
And hey, a bit of extra padding never hurts if you like carpets!
Thanks for the tips so far! I have an additional question about wall mounting: What type of fasteners do you recommend exactly? Are there special brackets for Kallax units, or do you use standard metal brackets?
Also, I have a relatively thick carpet, and the shelf is placed on it. Are there any thin anti-slip pads that I can put under the shelf on the carpet to reduce wobbling without raising the height too much? The pad should have enough grip to keep the furniture from shifting.
