Hello everyone, I’m considering using an Ikea PAX wardrobe in a slightly damp room—specifically, in my basement, which isn’t completely dry and may be affected by occasional moisture. My main question is: Is it generally advisable or even possible to use the Ikea PAX wardrobe in so-called damp rooms, or should I expect issues such as swelling, mold growth, or permanent damage due to the materials and construction? Additionally, I’m interested in whether there are any special measures that can be taken to ensure the wardrobe’s durability in such environments. I look forward to your insights and experiences!
sonrickey31 May 2015 11:53Bentnon schrieb:
Is it generally recommended or even possible to use the Ikea PAX wardrobe in so-called wet rooms, or should one expect problems such as swelling, mold growth, or permanent damage due to the materials and construction?Hey Bentnon! That’s a very good question. In short: Ikea PAX is generally not the best choice for permanently damp environments. The particle boards used in PAX are quite susceptible to moisture and tend to swell fairly quickly – over time, this can look quite bad and eventually make the wardrobe unusable. However, depending on how humid the room actually is and how well you can ventilate, you might be able to delay these issues a bit.
I would recommend considering an alternative solution if there’s no way to keep the room truly dry. Perhaps a moisture-resistant option made from metal or specially treated wood? If you do decide to go with PAX, make sure to keep the room well ventilated and consider protecting the back panels with a water-repellent film or similar. A bit of DIY effort can sometimes make a big difference. Good luck!
Bentnon schrieb:
Is it generally recommended or even possible to use the Ikea PAX wardrobe in so-called damp rooms, or should one expect issues such as swelling, mold growth, or permanent damage due to the materials and construction?To address your question with a more technical perspective: Ikea PAX is primarily made from particleboard with a melamine coating. While this coating is resistant to low levels of moisture, prolonged or high humidity causes the wood to absorb water like a sponge, leading to swelling of the particleboard. This often results in edge swelling, warping, and even separation of the coating along the edges.
Additionally, it is important to note that damp rooms have a much higher risk of mold growth on unprotected surfaces. PAX is not designed for bathrooms or wet basements—manufacturers usually recommend specific furniture systems for these areas, made from PVC, aluminum, or water-resistant wood.
If you still want to use PAX in a damp room, you can try the following:
- Ensure good ventilation, ideally with dehumidifiers
- Avoid placing the wardrobe directly on a damp floor
- Reinforce back panels with water-repellent materials
- Seal edges with silicone or special paints
My advice: Check the room’s humidity levels (ideally below 60% relative humidity) and how frequently damp conditions occur. If humidity is occasional and proper ventilation is maintained, you can achieve good results with these protective steps. Otherwise, it is better to avoid using PAX in damp rooms.
deoke schrieb:
PAX is primarily made of particleboard with a melamine coating. While this coating is resistant to minor moisture, the wood will absorb water like a sponge under sustained or high humidity, causing the particleboard to swell.A very good summary! I would like to add a few points, especially regarding practical handling if you still want to use PAX.
First: If you plan to place a PAX wardrobe in a basement or damp room, you should be careful about its position. The cabinet should not stand directly on the floor, nor should it touch wall areas with bubbles or moisture damage. Installing baseboards under the cabinet can be helpful.
Second: I recommend keeping the doors open when the room is not used for extended periods to improve air circulation. This helps the particleboard release moisture faster.
Third: In cases of strong fluctuations in humidity, I suggest using special water-resistant varnishes or impregnations that can be applied to edges and surfaces. This reduces the risk of mold and swelling.
In summary: PAX is not designed for damp rooms, but with additional protective and ventilation measures, its usability can be extended.
Sepele schrieb:
PAX is not designed for damp rooms, but with additional protective and ventilation measures, its usability can be extended.I am a bit more cautious about that. The PAX systems are made from cost-effective materials, which of course makes them appealing, but also brings certain limitations. Especially in damp rooms, the type of material is usually the crucial factor.
I wonder if occasional use in a basement room with elevated humidity might be somewhat reckless when considering the long-term effects. Potential damages, such as the constant swelling and shrinking of the material, can not only ruin the cabinet but also promote mold spores in the room, which can pose health risks.
Are there any reliable user experiences with PAX used over several years in damp rooms? Or are you only considering possible protective measures? I believe it makes more sense to address the issue technically and consider alternative furniture solutions that are actually certified for humid conditions, rather than relying on a half-hearted “improvement package” afterward.
