ᐅ Is it possible to assemble Ikea Brimnes shelves flexibly?
Created on: 8 Mar 2023 08:15
ligasau
I am currently planning to get a Brimnes shelving unit from Ikea, but I’m unsure how flexible the assembly is regarding dimensions and the arrangement of the compartments. Specifically, I’m interested in whether it’s possible to assemble the shelves so that individual sections can later be rearranged or modified – for example, changing the height of each section or adjusting the sizes of the compartments modularly.
Does anyone have experience with whether the Brimnes shelves only work as per the standardized assembly method suggested by Ikea, or if you can actually be flexible with the individual components?
Thanks for your insights!
Paxton38
8 Mar 2023 13:10
Brimnes is a fairly closed system from Ikea.
- There are no official flexible extensions available from Ikea.
- Accessories such as alternative shelves or connection strips are not widely offered by third-party suppliers, as the system is designed to be fixed and dimensionally stable.
- For custom modifications, DIY solutions are usually required.
If you want a lot of flexibility, you might want to consider other modular systems.
BOMILAN
9 Mar 2023 08:45
Basically, with Brimnes, you can assemble the individual cabinets separately and place them side by side, but the shelves inside each cabinet are not adjustable.
For custom modifications, drilling new holes is necessary, which may affect stability.
neoren
9 Mar 2023 09:12
I have Brimnes at home myself.
- The fixed shelves are set in permanent positions.
- Changing their positions is hardly possible without drilling new holes.
- Adjusting individual doors or components within the existing unit is somewhat possible but not quick.
So, you have to plan for fixed dimensions and arrangements.
Tinaneo
9 Mar 2023 09:47
In summary, the Brimnes shelving unit is solid and well-designed, but it does not offer true modular flexibility in terms of adjustable shelf heights or easy reconfiguration.
Its flexibility mainly lies in placing entire cabinet sections separately or fastening them together, while later modifications generally require new drilling, which can compromise stability.
For users who need regular or significant reconfiguration, the Brimnes is therefore likely less suitable.
ligasau
10 Mar 2023 13:22
Thanks to everyone for the detailed and factual responses!
This has clarified the question for me about whether Brimnes offers a flexible modular solution – probably not.
I will use the shelf as a stable standard solution and proceed with caution if any rearrangements are necessary, or I will turn to other systems that put more emphasis on modularity.
It's great to read so many different perspectives here – that really helps with the decision-making. Thank you!
