ᐅ Is it possible to assemble Ikea Brimnes shelves flexibly?
Created on: 8 Mar 2023 08:15
ligasau
I am currently planning to get a Brimnes shelving unit from Ikea, but I’m unsure how flexible the assembly is regarding dimensions and the arrangement of the compartments. Specifically, I’m interested in whether it’s possible to assemble the shelves so that individual sections can later be rearranged or modified – for example, changing the height of each section or adjusting the sizes of the compartments modularly.
Does anyone have experience with whether the Brimnes shelves only work as per the standardized assembly method suggested by Ikea, or if you can actually be flexible with the individual components?
Thanks for your insights!
Tinaneo
8 Mar 2023 10:44
Leland schrieb:
The Brimnes shelves are not designed for adjustable shelf heights.
That seems to be the core issue.
If Ikea standardizes the cabinet holes, it suggests that the manufacturer does not expect flexibility, but rather a fixed installation. If adjustable positioning had been intended, they would likely have included elongated holes or additional drill rows.
JORGERON schrieb:
Individual shelves can be repositioned if fixed with dowels and screws, but the standard drillings are not designed for this.
This confirms that practical modifications are possible, but they require effort and compromise the stability.
ligasau
8 Mar 2023 11:15
That helps already, thank you!
One more additional question: How is the arrangement of multiple Brimnes units?
Can these be connected flexibly, for example, stacking elements of different heights or arranging them side by side?
Or is a more rigid setup expected here too, for example, due to fixed connection mechanisms or a lack of modularity in the design?
Blavin
8 Mar 2023 11:54
Several Brimnes modules can generally be connected, but only within certain limits. The design is focused on individual units.
- Placing them side by side is possible by positioning them next to each other and securing them with brackets.
- Stacking individual units is safe only if they are firmly anchored to the wall.
- The modules are not designed for flexible combinations using connecting fittings, so custom solutions should be applied.
The standard design does not include built-in connection points for combining modules.
derrick34
8 Mar 2023 12:10
It is important that Brimnes units are individually stable.
When combining them, always ensure they are secured to the wall, otherwise they can easily tip over.
Modular side-by-side or stacked connections are not intended.
Tinaneo
8 Mar 2023 12:27
That’s a good point.
It seems that Ikea has designed the units more with individual stability in mind rather than creating a true modular system based on a kit principle.
I suspect this is a deliberate compromise between cost, ease of assembly, and the expectations of the target audience.
Therefore, flexibility for modifications during ongoing use is likely to be limited.
ligasau
8 Mar 2023 12:53
Very helpful, thank you!
What I would also find interesting: Are there any accessories or extensions for Brimnes from Ikea or third-party suppliers that offer more flexibility – for example, different shelves, adapters, or connecting fittings? Or is the model rather 'closed,' meaning that custom modifications require DIY solutions?
