ᐅ Is it possible to retrofit IKEA Metod drawers with additional soft-close damping?
Created on: 14 Sep 2016 08:43
EllakeoHello everyone, I currently have Metod kitchen drawers from IKEA installed and am wondering if it is possible to retrofit these drawers with additional damping. I am specifically thinking of some kind of soft-close system or at least an addition that cushions the drawer closing without having to replace the entire drawer slide. Unfortunately, I can’t find any official retrofit solutions for Metod drawers from IKEA itself, and information online is quite limited. Maybe someone has experience or a practical DIY solution? It would also be important to know if additional damping components fit structurally and how complex the installation is. Thanks in advance for any tips and advice!
Yes, that works. There are soft-close modules that you can clip onto the existing drawer slides. IKEA itself does not sell these separately for Metod, but you can find suitable retrofit kits at specialist retailers or online. It is important that the drawers are compatible with the slides.
I had the same issue at my home 😊. My tip: buy soft-close adapters specifically designed for ball-bearing drawer slides. They are easy to install and make the drawer close smoothly – almost like magic! The best part: you immediately notice how much more high-quality the drawers feel. Some basic DIY skills help, but it’s not rocket science.
To answer the question thoroughly, you first need to understand the underlying mechanics of the Metod drawers. These often use telescopic runners that allow the drawer to be pulled out almost completely. The soft-close systems usually operate via hydraulic or mechanical soft-close elements that are installed in or on the runners. Since IKEA does not offer separate soft-close modules for Metod, aftermarket components from third-party suppliers are necessary.
When retrofitting, the following points are especially important:
- Does the soft-close module mechanically fit the existing runner?
- How is the installation carried out? Are screws required, or are there clamping systems?
- What load can the damper handle without damage?
- Can the length of the drawer or runner affect the installation?
In practice, specialized soft-close adapters are often attached inside the runners on both sides. The drawer is then reinserted as usual, with the mechanism gently damping the closing action. Some solutions require the drawer to be removed in order to install the dampers. It is also important to avoid using screws on load-bearing parts that could compromise stability.
Finally, a note: some users report finding well-fitting and affordable adapter kits on various platforms. However, before purchasing, you should check compatibility and review the installation instructions carefully. I have retrofitted Metod myself and was satisfied with the result, although I had to make some adjustments during installation.
Feel free to share your exact measurements or drawer type (e.g., width, runner type), and I can provide more precise advice.
Lance schrieb:
Feel free to share your specific dimensions or drawer type (e.g., width, runner type), and I can provide more precise advice.Thanks in advance for the detailed explanation. My drawers are 60 cm (24 inches) wide and come with the original Metod telescopic runners (full-extension slides). The drawers have a metal side panel, which should be quite sturdy. I had hoped I could simply attach any soft-close damper either clipped on or mounted on the runner, but it seems not that simple. Do you have any recommendations for manufacturers or products that fit particularly well? Also, I’m curious whether I need to remove the drawers completely to install the dampers or if it’s possible to fit them with the drawer still in place.
Here is a brief guide on how to approach retrofitting:
1. Fully pull out the drawer and, if possible, remove it – there is usually a release mechanism on the slides.
2. Find suitable soft-close adapters for full-extension telescopic slides (for example, from manufacturers like Blum or Hettich, who often offer compatible products).
3. Install the adapters onto the slide according to the manufacturer’s instructions. Usually, the damper is pushed to the back end of the slide and secured by a clip or screw.
4. Reinsert the drawer and test the closing mechanism.
Important: Some dampers only work with certain depths or result in a slightly shorter extension, so this should be checked before purchasing.
If you leave the drawers in place, it is usually difficult to position and secure the damper correctly – removing the drawer is therefore recommended.
