ᐅ Is it possible to paint or apply a veneer/film to IKEA PLATSA units as an alternative finish?
Created on: 4 Mar 2018 08:12
Sinderim
Hello everyone, I recently purchased an IKEA Platsa shelving system and am considering customizing its appearance. I’m interested in whether it makes sense to paint or apply a film to these furniture pieces in order to change their surface or color. Specifically, my question is: Can IKEA Platsa be painted or covered with a film without compromising the quality or stability of the surface? I would like to know if the surface is suitable for this, what kind of preparation might be necessary, and if there are particular types of paint or films that work especially well with this material and furniture series. Thanks in advance!
KarTristan
5 Mar 2018 07:54
Sinderim schrieb:
Can I alternatively paint or apply a film to IKEA PLATSA without compromising the quality or stability of the surface?
To add to the previous answers: The stability of the furniture is not affected by paint or film, as only the surface is treated. It is important to use the right products, such as a suitable primer when painting and a high-quality film. Climate and usage also play a role, so careful preparation is essential to prevent later peeling or chipping.
Merlin
6 Mar 2018 12:26
The film will only adhere properly if the piece of furniture is free of wear marks and dust. Applying a primer followed by several coats of paint results in a durable finish.
funau
7 Mar 2018 09:38
On the technical side: The surface of Platsa is usually made of melamine-coated wood-based material. It is very durable but has a low porosity and a smooth texture, which makes adhesion more challenging. Therefore, proper surface preparation is necessary before painting, preferably light sanding with fine-grit sandpaper (grit 220-320) and cleaning with a degreasing agent. For laminates, specially designed PVC films with high elasticity suited for furniture are recommended. The durability of the lamination also depends on the quality of the application and the level of wear and tear.
V
vinicius44
7 Mar 2018 16:45
funau schrieb:
The surface of PLATSA is usually made of melamine-coated wood-based material. It is very durable but has a low porosity and a smooth finish, which makes adhesion difficult.
Exactly, that’s the key point. That’s why I strongly recommend always using a primer; otherwise, after a short time, you’ll face issues with paint or foil peeling off. If you want to avoid sanding, you can also try adhesion promoters, but sanding remains the most reliable method.
