Plot size: 635 sqm (6,839 sq ft)
Floor area ratio (FAR): 0.4
Site occupancy index: 0.3
Roof style: 35° to 45° pitch, hipped roof or gable roof
Distance to front property boundary (street side): max. 3 m (house must remain in current position)
Homeowner Requirements
Style, roof type, building type: Bungalow, hipped roof, 35° pitch
Basement, floors: no basement, 1 story, possible attic conversion later
Number of occupants, age: 2 persons (40 years old), probably no children, room can be separated if needed
Space requirements: We need one bedroom, bathroom, utility room, living area including kitchen, and a hobby room (gaming and crafting room). Walk-in closet and guest toilet were removed, even though they would be nice, other features took higher priority.
Overnight guests per year: infrequent, can be accommodated as is
Construction style: open and modern, including open kitchen
Fireplace: no
Designer:
- Designer from a construction company implemented our drawings
What do you like most? Why?
- Large living area, spacious bedroom
What do you dislike? Why?
- Honestly, we like everything
Personal budget for house including fittings: 260,000
Preferred heating system: air heat pump
We initially sketched our design on paper, which the designer then realized. Further considerations and discussions with the designer shaped the final result.
Our main goal was a large living space with an open kitchen and a reading nook. Currently (in our present apartment) we have another room with my books (around 1,000) and desk, but I rarely spend time there, as I do everything in the living room. For this reason, we first reduced the number of rooms to enlarge the living area and bedroom (we omitted the walk-in closet to create even more space). The reading nook (located on the west side of the living area) is arranged so it can be separated as a room from the rest of the living room if needed.
We made sure the bedroom faces east to get morning light. We opted out of a guest toilet and instead planned a small storage room for odds and ends (dog supplies like food, leashes, vacuum cleaner, etc.) and made the utility room somewhat larger than the usual 8 sqm (86 sq ft).
Currently, we are still unsure about the following:
- Bathroom layout: I’d like to set back the shower slightly (see current floor plan) to make the bathroom feel more open/bigger. Somehow it still doesn’t feel quite ideal.
- Window arrangement: Does this make sense to you? Will we get enough light in the living area? The floor-to-ceiling windows to the terrace are on the east side, so only the morning sun comes in there. Are the south-facing windows sufficient?
Is there anything we have overlooked or forgotten? From your perspective, is anything highly unfavorable? Any improvements for the windows? How can the bathroom layout be optimized?
By the way, some time ago I created a thread about a 1.5-storey floor plan on the same plot. At that time, we ultimately decided to build a bungalow – which we are now doing. Hence, this new thread…
Best regards and thanks in advance.
Fireplace: no
Designer:
I estimate that the price difference between standard patio doors and sliding patio doors is greater than that between standard interior doors and sliding interior doors. There are even websites where you can order custom-made doors. These are usually the same companies that offer custom wardrobes.
One more thing I noticed in the new floor plan: the access from the kitchen to the terrace is no longer as close as before, but is that something you care about a lot?
Reluctance8 Jul 2019 20:24Niloa schrieb:
What I also noticed about the new floor plan: the path from the kitchen to the terrace isn’t as close as before, but do you really consider that important? Yes, that’s true. It’s not ideal. I also miss the large window wall facing the garden. Basically, the current floor plan was developed based on several considerations:
- Books/my area not directly visible but still part of the living area
- Living room facing the garden with a large window wall
- Direct access from the hallway straight into the kitchen as the first room
So it mostly fits these points. It’s just that the layout doesn’t seem to be optimal to create a clear structure...
I’ll start by looking at the Alno kitchen planner now...
