Created on: 27 May 2019 10:48
goalkeeper
Winniefred25 Feb 2020 13:01
I also think it’s best to remind him about it once more. How much time do you have left for the objection? Since when have the 14 days been running?
11ant25 Feb 2020 13:23
Those who are worried, relax!
This objection will cost the neighbor 200 euros for an additional round in the notification procedure and—since they already know Goalkeeper’s substantive objection and can submit their corrected documents—won’t cause much delay. Waiving this objection would actually do more harm than good: the authority would not be warned by explained concerns and would approve the project, the neighbor’s builder would carry out the faulty work, damage would result, and claims for compensation would follow. This is not the start of a permanent feud, but almost a sportsmanlike duty to prevent the inexperienced builder from heading into this disaster.
goalkeeper
25 Feb 2020 16:04
After several phone calls with our general contractor, the neighbor’s architect, and the neighbor directly, there are some new insights:
Our general contractor clearly states that the basement is even 40cm (16 inches) too deep. Since you cannot simply dig straight down to the “ground zero” level, the foundation still needs to rest about 10cm (4 inches) “in the sand,” which results in the 40cm (16 inches) difference.
I then discussed this with the neighbor’s architect. His opinion is that depending on the soil type, underpinning might not be necessary up to 30cm (12 inches). He was not even aware of the 10cm (4 inches) “in the sand” detail. That made me a bit cautious. He now knows our position and will talk to the client.
Afterwards, I had a phone call with our neighbor and explained everything, including that we will formally file an objection. He didn’t see it as a big problem — he definitely does not want to do any underpinning, so they will likely have to revise their plans.
On the other hand, our general contractor also informed us that we will probably be able to move into the house starting May 11 — good news amid all the hectic activity.
tomtom7925 Feb 2020 17:36
goalkeeper schrieb:
His opinion on this is that depending on the soil type, underpinning would not be necessary up to 30cm (12 inches). He was not even aware of the 10cm (4 inches) “in the sand” issue.
If the architect didn’t know that, then he’s incompetent, or he truly doesn’t know—but in that case, I would be cautious because many other things could go wrong. Or he might be cutting corners on underpinning at your expense.
goalkeeper
25 Feb 2020 17:54
tomtom79 schrieb:
if the architect didn’t know, then he’s useless, or he really doesn’t know, but in that case I would be cautious because many other things could go wrong. Or he might be cutting corners on the underpinning at your expense.
Well, the architect is only responsible for the design – everything else is handled through individual contracts. So he would have no benefit from skipping the underpinning.
However, he now knows that we, as neighbors, are not fools who wouldn’t notice. We will keep a close watch on this.
goalkeeper
26 Feb 2020 16:39
The underfloor heating is almost fully installed, so the screed can be poured on time by March 9th.
Underfloor heating: White pipes arranged in a spiral pattern on insulation underlay, red clips.
Room under construction: Underfloor heating with white pipes in spiral patterns, materials ready.
Underfloor heating: White pipes looped on insulation panel, unfinished room with a window.
Underfloor heating: White pipes spiral-shaped on reflective insulation foil indoors.
