Some time ago, I bought a Billy bookshelf from IKEA and noticed that the shelves noticeably bend under moderate weight, which affects both the overall appearance and stability. According to the product description, the shelves are 16 mm (5/8 inch) thick and made of medium-density fiberboard (MDF) with a melamine resin coating. There are no extremely heavy items on them, mostly books and some decorative objects, but nothing excessive.
My question is: What options are available to prevent or at least significantly reduce the bending of the shelves? I have read about some people supporting the boards differently or adding extra reinforcements. But are there also simple, practical solutions or recommendations for alternative shelves that would fit?
I would appreciate any helpful tips and experiences!
Ryder35 schrieb:
Using center supports is the most effective way to prevent sagging.Thanks for the tip. Can anyone suggest where to find suitable center supports for Billy shelves? Or are these just standard universal parts available at hardware stores? Do I need any special fasteners for this?
I would appreciate any advice, as I’m not very experienced with DIY and need simple solutions.
flose schrieb:
Can anyone say where to get suitable center supports for Billy shelves?Good morning,
usually, you can find so-called "shelf supports" or "center brackets" for shelves at a hardware store. They are typically made of metal and come as small feet that are simply screwed onto the underside of the shelves. You can also attach a strip to the back panel of the shelf, on which a vertical support is then placed.
It is important to measure carefully beforehand to ensure the distance between the base panel and the top of the shelf is correct.
If this seems too complicated, there are also shelf supports with integrated center braces that you can insert between the base and the shelf – a bit easier to handle. It’s always a good idea to visit a hardware store in person first and ask questions, as the selection is quite large.
