ᐅ Kallax shelves cracking at the corners – any repair suggestions?
Created on: 22 May 2021 08:17
teo-fra
teo-fra
22 May 2021 08:17
Hello everyone, I have an issue with my Kallax shelf: the shelves keep cracking at the corners, even though I only store normal loads on them. It seems like the material reinforcement at the corners is simply not sufficient, or the wood is somehow too brittle. Has anyone experienced this problem before? I’m especially interested in repair ideas that provide more than just a short-term fix and actually improve the stability of the boards. Tips for prevention to stop the corners from fraying further are also welcome. Thanks in advance for your help!
Domau0
22 May 2021 08:46
Hello teo-fra,
First of all: your assessment sounds correct – the Kallax panels are made of particleboard with a melamine coating, and the corners are particularly vulnerable because pressure and stress tend to be concentrated there.
My recommendation is to proceed step by step: first, you should check whether the shelves are properly seated in the grooves and whether any stress is caused by incorrect assembly. Especially if the shelf unit is slightly tilted, it can lead to unexpected loads.
Regarding the repair itself:
- You can secure the corners with wood glue and reinforcing felt or plastic clamps to prevent further splitting.
- A somewhat more robust solution is to attach small metal brackets underneath or along the edges to reduce stress. Make sure to pre-drill holes to avoid creating new cracks.
- If you have some DIY skills, you can also work with epoxy resin: this will strengthen the area and likely improve stability significantly.
Is the shelving heavily loaded or mainly used for decoration? Depending on the load, I would adjust the repair accordingly.
One more note: I have also seen that the edges often deteriorate due to moisture – make sure nothing stays wet permanently.
What kind of items are you storing exactly? That will help to better assess the solution.
teo-fra
22 May 2021 09:04
Domau0 schrieb:
Is the shelf heavily loaded or mainly for decoration? Depending on the load, I would tailor the repair.
Thanks for the detailed advice!
The shelf is mainly used for books and some folders. So, no extreme load, but it is regularly loaded and unloaded. The corners are mostly splitting at the lower joints, so the stress seems to be concentrated on impact areas.
One more question about your recommendation with epoxy resin: Is there a specific type that is especially suitable for this purpose? Or is standard epoxy resin from a hardware store sufficient? I want a durable and stable solution.
Domau0
22 May 2021 09:42
On the topic of epoxy resin:
There are actually several types available. For furniture repairs, I usually recommend a two-component epoxy resin with medium viscosity that spreads well but doesn’t run too much. This way, you can precisely reinforce the edges without much dripping.
I would suggest choosing a version that can be lightly sanded and painted over once cured, in case you want to do additional work later.
Important: Mix thoroughly and pay attention to the curing time! If you apply it too thickly, the inside may remain sticky.
At hardware stores, you often find products designed specifically for wood repairs. If you shop online, look for "epoxy resin wood repair."
One more tip: Before applying, clean the corners well and roughen the surface to improve adhesion.
TANBLA
22 May 2021 10:03
Apply wood glue to the cracks, then reinforce the corners with metal brackets. This will ensure longer durability.
tutan
22 May 2021 10:28
Kallax shelves and corners can be quite a challenge! 😄
I experimented a bit and simply covered the corners with standard plastic edge protectors, the kind used for furniture edges. They are inexpensive, provide good protection against further cracks, and even look quite neat.
This adds a bit more durability without requiring much effort. Plus, if needed, you can replace them fairly easily.
If you’re not just planning to store boxes there, give this kind of protection a try. 🙂
