I recently have a BILLY shelf from Ikea, which comes with a standard white lacquer finish. Unfortunately, the lacquer has slightly peeled off at one corner due to an accidental touch, exposing the underlying wood. My question is how to best repair this lacquer damage so that the spot looks good again and remains as inconspicuous as possible.
I would like to know which products or methods have proven effective: Should I use a special touch-up paint pen, or is it better to lightly sand the area and repaint it completely? Additionally, I’m interested in the best approach for smooth lacquered surfaces to avoid noticeable edges or stains.
I look forward to your tips and experiences!
pierce57 schrieb:
how I can best repair this paint damage so that the spot looks good again and remains as inconspicuous as possible.Hi! The best option is usually a touch-up paint pen from a hardware store that matches the BILLY paint color. These are often affordable and perfect for small repairs. Before you start, lightly sand the area so the paint adheres better – but don’t sand too aggressively, or you’ll create more work for yourself.
I’ve done this a few times myself and find that a paint pen is much faster and cleaner than using a brush or spray. Also, take your time applying several thin layers, so the repair becomes almost invisible. Good luck! 🙂
pierce57 schrieb:
Should I use a special touch-up paint pen, or is it better to lightly sand the area and repaint it completely?For minor paint damage on Ikea BILLY shelves, I recommend the following approach:
1. Clean the surface thoroughly, removing any grease and dust
2. Lightly sand the damaged area using fine sandpaper (grit about 220-320) just enough to create a smooth edge
3. Use an acrylic or furniture touch-up paint pen or a small can of paint matched to the white color of the shelf
4. Apply the paint in thin layers, allowing each layer to dry completely
For larger or more widespread damage, a complete repaint of the affected shelf part may be more effective. In this case, using a fine brush or a small paint roller is preferable. However, paint pens are especially suitable for spot repairs. The risk of visible transitions can be reduced by proper surface preparation and careful application.
pierce57 schrieb:
Also, I’m interested in the best way to work on smooth painted surfaces without creating noticeable transitions or marks.Repairing paint damage on a BILLY shelf requires precision, especially because of the smooth, satin finish:
First, gently sand the damaged area with 320-grit or finer sandpaper, ensuring a smooth transition to the undamaged painted surface—sharp edges will show through later.
Then be sure to thoroughly clean the surface of dust and grease. I recommend isopropyl alcohol (cleaning alcohol) or window cleaner to avoid leaving any residues.
For the paint itself, acrylic or furniture touch-up paint works best, as it dries relatively quickly and has only a slight sheen. Paint pens are convenient but only if the color matches exactly. Sometimes a small brush with very fine bristles is worthwhile.
It is important to apply the paint in several very thin layers—allow each layer to dry fully to prevent drips or bubbles. Sanding between layers is often unnecessary for very small areas but can help with uneven paint layers if you want to work very carefully.
If you’re uncertain, first test on a small, inconspicuous spot or the inside of the shelf.
One more rhetorical question for you: How large is the damaged area exactly? This also influences the choice of materials.
Surela schrieb:
How big exactly is the damaged area?I'll answer pragmatically: For small scratches or just a few square millimeters, a touch-up paint pen is the best option.
For larger chipped areas, you should lightly sand the surface, apply a primer, and then add a fresh layer of paint.
Careful preparation before painting helps avoid visible transitions.
