ᐅ Billy Shelf - Easy to Dismantle.
Created on: 15 Jun 2024 10:17
Rolen
I am currently facing the challenge of having to disassemble a Billy bookshelf and would like to know how to do this as easily as possible and without causing any damage.
My main concern is safely removing the individual shelves and side panels so that I can transport the furniture in a space-saving way and later reassemble it.
Are there any special tips for IKEA Billy bookshelves, for example regarding the attachment of the back panel or the dowels, that I should be aware of?
I have some experience with furniture assembly, but I often get worried about breaking something during disassembly.
What are your best tips and perhaps recommendations for tools? Thanks in advance for any advice!
likuken
15 Jun 2024 14:09
Domau0 schrieb:
I recommend starting by removing the back panel. It is usually fixed with small clips.
I believe this is the worst possible approach. The back panel provides the entire shelf unit with its stability, so it’s best to remove it last; otherwise, everything will wobble, and it becomes difficult to properly loosen the remaining screws.
Also, constantly unscrewing screws is overrated. I once completely disassembled my shelf simply by fully removing the back panel first and then loosening the side shelves. Minimal effort, maximum time saved—of course, assuming you don’t want to check every single screw individually. But it works! 🙂
Domau0
15 Jun 2024 14:37
likuken schrieb:
The back panel provides the entire shelving unit with its stability; it’s best to remove it last
That is generally true, yes, but with a Billy shelf unit, there are several attachment points on the sides that also ensure stability, as long as you work carefully.
If the back panel is pulled off at an angle, there is a risk it could bend or interfere with disassembling the other parts.
likuken schrieb:
minimal effort, maximum time saving
That might apply in some cases, but I recommend disassembling step by step to ensure the later reassembly works smoothly and no components get bent.
How much use has your shelf already had? Is it still stable, or are there visible signs of wear?
likuken
15 Jun 2024 15:05
Domau0 schrieb:
I recommend disassembling step by step to ensure later reassembly works smoothly
I understand your careful approach, but my experience shows that people often get too picky with these Billy shelves. They are sturdy and can handle a bit of rough treatment as long as you’re somewhat careful.
And yes, the shelf has no damage; I’ve been using it for 5 years without any problems. So I agree with you that signs of wear are important. But if you know how to pull and lever correctly, you can save time.
Maybe it’s just a matter of style 🙂
Rolen
15 Jun 2024 15:28
Interesting discussion, thank you all.
I am weighing your arguments: whether to remove the back panel last or first in a step-by-step process.
The shelf is still quite new, with no obvious signs of wear, so I want to avoid damage as much as possible.
Are there any other tips specifically for screwing the shelves back during reassembly? For example, how to best handle the small Minifix fittings when using them multiple times?
nubar
16 Jun 2024 09:17
Good morning,
when repeatedly assembling and disassembling Minifix connectors, I recommend checking the screws and dowels before reinstallation. Minor wear can be easily fixed by gently tightening the Minifix screws, but avoid overtightening as this can reduce their holding strength.
If the dowels are a bit loose, applying a drop of wood glue to reposition them can help ensure a firm fit. Use the glue sparingly, however, if you plan to disassemble the shelf frequently.
Additionally: when assembling, always work with light pressure, align the components properly before fully tightening the screws.
Kinbu
16 Jun 2024 09:45
In addition to the Minifix system, there are so-called mini connector clips available as replacement parts from Ikea. If any of the original parts are damaged, it’s worth upgrading to ensure stable connections.
I also recommend tightening the screws for the shelves only by hand at first, then securing them with a screwdriver. This way, you can correct any misalignments before everything is fully tightened.
And very important: it’s best to assemble the shelves with two people or to secure them against unwanted warping.
