ᐅ Why is the Billy bookshelf still wobbly despite wall anchoring?
Created on: 16 Feb 2021 08:17
pipekeHello everyone,
I have anchored a Billy bookcase combination to the wall, but the furniture still wobbles noticeably, especially when you shake it or place something inside. The plugs and screws are firmly installed, the wall is solid (concrete), and I followed the assembly instructions precisely. Still, it wobbles.
Can someone explain why this might be? Is it related to the design of the Billy shelving unit itself, or are there specific aspects of wall mounting that should be considered? I would like to understand what is causing the issue so I can find a solution if needed.
Thanks for your advice!
pipeke schrieb:
The anchors and screws are firmly in place, the wall is solid (concrete), and I followed the installation instructions exactly.Still, there’s some wobbling... That makes me curious. Sometimes it’s simply due to minimal tolerances or how the back panel of the Billy unit is installed. It’s actually just a thin particleboard and doesn’t add much stability to the cabinet.
It might help to carefully check the back panel again to ensure it sits completely flush and is nailed or screwed firmly all around. 🙂
Or have you tried checking if the mounting screws have any slight play in the wall anchors?
Hello pipeke,
You have already chosen a sturdy wall and followed the instructions, which is good. However, Billy-style shelves are known to be somewhat "flexible" in construction. The side panels and shelves are usually made of thin particleboard, which can easily bend under load.
Additionally, the wobbling may also be caused by screws and anchors being tight, but the actual connection not being completely flush. For example, if the wall-mounting screws are not installed perfectly level, it can cause rocking movements.
My recommendation: Check whether the shelf is standing completely straight and all levels are flush. Also, tightening all screws again can help, especially if the shelf has been in place for some time.
This is great, tackling such a practical problem right here! 🙂
I always find it interesting how a simple piece of furniture like the Billy bookshelf can become tricky. For me, adding an extra cross brace helped improve stability. It’s not original, but very effective against wobbling!
You might also consider using foam pads between the shelf and the wall – they slightly dampen movement, a little trick like that. 😊
Keep it up, and don’t let a wobbly Billy bother you!
pipeke schrieb:
Nevertheless, the piece of furniture noticeably wobbles, especially when you shake it or place something inside.I completely understand that this is annoying, especially when you put a lot of weight on the shelf and it starts to wobble. It creates an uncomfortable feeling of instability.
From my experience, the back panel plays a major role with Billy units. It is often only attached with small nails, which is not very stable. If you want, you could try securing the back panel additionally with small screws or strong tape – this can improve stability.
It is also important that the wall anchoring is at the level of the upper shelves, because otherwise leverage forces can cause the shelving unit to move.
