ᐅ Installing Billy Shelving with Minimal Noise from Doors – Recommendations
Created on: 30 Jun 2017 10:17
georgi64
georgi64
30 Jun 2017 10:17
I am planning to install new doors on my Billy bookshelf and want to make sure the doors close as quietly as possible. That means the doors should close smoothly without loud noises, clicks, or bangs. I’ve heard that special hinges or dampers can be used for this, but I’m not sure which solutions work best.
The doors need to fit well, and the installation should be as straightforward as possible. Do you have any experience with suitable hinges, dampers, or other accessories to make the Billy bookshelf as quiet as possible? Tips, specific product recommendations, or installation advice would be greatly appreciated!
Looking forward to your suggestions.
blaix
30 Jun 2017 11:23
georgi64 schrieb:
I am planning to install new doors on my Billy bookcase and want to use the quietest possible doors.
That’s a good idea, but don’t you think the issue is usually not just with the hinges? Often, the edges of the doors or the strike plate also cause noise.
What exactly do you mean by “quiet doors”? Just soft-close hinges, or also a way to dampen the entire closing process? I often see that soft-close hinges are quieter, but don’t necessarily guarantee silent closing if the door panel is not fitted precisely.
Have you also checked whether the standard Billy doors are suitable for these types of hinges? Not all combinations fit easily.
luAlbert1
30 Jun 2017 13:07
I think the effect of soft-close hinges on low-cost furniture like Billy is often overestimated.
blaix schrieb:
Soft-close hinges are quieter but don’t necessarily guarantee completely silent closing
I can only agree with that. In my experience, these hinges are a kind of placebo: the closing sound is dampened, but it rarely becomes completely silent—especially if the door isn’t perfectly aligned or if the laminated wood edge is uneven.
My advice: it’s better to equip the doors with felt or rubber bumpers at contact points and ensure proper adjustment. This naturally reduces loud bangs more effectively than enthusiastic soft-close tinkering.
JAPLO
1 Jul 2017 08:45
In this case, I would recommend a combination of soft-close hinges and cushioning bumpers.
IKEA Billy doors can usually be retrofitted with special soft-close hinges, which are also available from third-party suppliers. It is important to ensure correct alignment and adjustment during installation to prevent the doors from sticking.
Additionally, small rubber bumpers or felt strips at the contact points can significantly reduce noise by cushioning the contact between the door and the shelving unit.
It is also worth considering whether to use the old doors or new, specially fitted doors. New doors with a smooth surface and precise construction often close more quietly.
For the installation: If you have no experience with furniture fittings, it is advisable to carefully read the assembly instructions for the hinges. Often, a screwdriver with a magnetic tip or even a drill with damping at low speed is needed.
Lucki
1 Jul 2017 10:53
That’s amazing how many options there are 🙂
I also installed soft-close hinges from Hettich on my Billy bookshelf – it’s an incredible improvement!
Additionally, I glued small silicone buffers between the door and the frame. The result: you hardly hear anything anymore, and the doors close very smoothly.
Just give it a try; it’s definitely worth it! I can only recommend not to skimp on the quality of the hinges, otherwise you quickly notice the reduced performance.
blaix
1 Jul 2017 11:29
Lucki schrieb:
I also installed soft-close hinges from Hettich on my Billy shelf unit – it’s an incredible improvement!
Congratulations on that! I’m curious about how you managed the installation technically.
The standard Billy hinge holes are designed for Ikea’s own hinges.
Did you use completely new doors, or did you modify the original doors? And how did you attach the dampers/silicone buffers? Simply glued on or mechanically fixed? I’m especially interested in the durability.
Without proper fastening, such a modification can quickly become ineffective.
