á Installing Ikea METOD drawers for smooth operation and soft closing adjustment
Created on: 13 Mar 2015 09:17
LeogauHello everyone, I recently purchased a kitchen using the Ikea METOD system and am now facing a challenge during the installation of the drawers thatâs been on my mind: How can I install the METOD drawers so that they glide smoothly while the soft-close feature is optimally adjusted?
Iâve noticed that my drawers sometimes feel rather stiff and the soft-close function doesnât always work consistently. It seems to be related to the alignment and the damping adjustment.
Iâve already reviewed some assembly instructions, but they are a bit too general in some areas. Iâm especially interested in:
- Is there a specific technique or order for installing the drawer slides that has proven effective?
- How can I best adjust the damping so itâs neither too strong nor too weak?
- Are there any tips for making the drawers slide particularly smoothly without them sticking or being too loose?
Iâd appreciate detailed experiences, potential pitfalls during installation, and concrete advice, preferably with explanations of why these steps matter. This will surely help many others facing the same issue.
Hello Leogau,
I can definitely understand your question, as mounting drawers and achieving soft closing can sometimes be trickier than expected. The most important thing is to ensure that the drawer slides are mounted perfectly parallel and at the same height. Even slight misalignments can cause the drawer to be hard to open or to get stuck.
Regarding adjusting the damping: Most METOD slides have small adjustment screws or sliders that allow you to regulate the strength of the soft-close mechanism. It usually makes sense to start with a relatively low setting and then increase it step by step if needed. It is important that the drawer not only slows down gently when closing but also fully closes â meaning it shouldnât sit too loosely.
Besides precisely aligning the slides and correctly adjusting the damping, the way the drawer itself is screwed on can also have an impact. Itâs best to carefully follow the instructions and avoid overtightening any parts.
If your drawers are still very hard to move, it might help to carefully apply a small amount of silicone spray to the railsâuse sparingly and with caution! Avoid using oils, as they tend to attract dirt.
I hope this helps! If you want, Iâm happy to provide step-by-step tips as well.
Iâd like to add a simple, structured approach that I always recommend for METOD drawers:
- Step 1: Use a spirit level to check that the side panels are perfectly vertical and parallel.
- Step 2: Attach the drawer runners exactly at the specified drill holes, but donât fully tighten them until the end. Temporarily fixing them allows for small adjustments.
- Step 3: Hang the drawer and check if it slides smoothly without catching anywhere.
- Step 4: Adjust the soft-close damping correctly: usually, you can fine-tune the damper on the runner. Tip: start testing at the lowest setting and then adjust gradually.
- Step 5: Very important: avoid using excessive force during assembly. Screws should be tight but still allow for fine adjustments.
Common mistakes I see:
- Runners installed unevenly
- Damper set too tightly, which can slow down the drawer
- Drawer front mounted incorrectly, causing the weight to be distributed unfavorably
Finally: sometimes it helps to clean the runners before installation or wipe them down if there is construction dust. This greatly improves the sliding action.
I hope this helps you all!
Ixvin schrieb:
To adjust the damping: Most METOD runners have small screws or sliders that allow you to control the strength of the damper.Thatâs correct, the right runner usually has these sliders that can be pushed in or pulled out, depending on how strong you want the damping to be.
If the drawer slows down too abruptly, simply loosen it slightly; that is usually enough.
I want to add some technical details and possible challenges regarding METOD drawers to this thread.
The smooth operation of the drawers depends heavily on the correct installation of the metal runners â there are a few important points to consider here:
- When inserting the runners into the carcasses, be sure to position them precisely, especially with regard to the correct height alignment and parallelism of the rails. Even small deviations of one to two millimeters (about 0.04 to 0.08 inches) can have a significant impact on how smoothly the drawer runs.
- The dampers on the METOD slides operate via a small hydraulic system. Some models offer mechanical adjustment, often through a small white or gray slider that can modify the end damping. Itâs best to adjust this with the drawer slightly pulled out to test the effect.
- My tip for installation: first tighten screws only by hand, then hang the drawer and open and close it several times to feel for any play in the construction. After that, fully tighten all screws to ensure a secure fit.
- Glide bearings or plastic guides should not be treated with oil, as grease attracts dust over time and will reduce smoothness in the long run.
- If the drawer still feels stiff or sticky, itâs often due to doors or fronts that are not sitting perfectly on the base frame. These can cause uneven pressure distribution.
Finally, a question for you, Leogau: Are you working with the standard METOD drawers, or do you perhaps have different versions, such as full-extension drawers or third-party models with integrated damping? This can affect the adjustment process.
Leogau schrieb:
How can I best adjust the damping so that it is neither too strong nor too weak?Thatâs a good question, and one I hear often. In my experience:
- Itâs best to start with a low damping setting and then test how the drawer closes.
- If the drawer still slams shut too hard, gradually increase the damping.
- Important: The drawer should stop softly before slamming but should not get stuck while closing.
asete schrieb:
If the drawer still feels stiff or catches, itâs often due to the doors/fronts not being perfectly aligned with the frame.I would agree with that. Sometimes just a small adjustment of the front panel can make everything run more smoothly.
One more tip regarding installation: Also check if the drawer sides (inside) are damaged or warped â this can have a major impact on how smoothly the drawer operates.
