ᐅ Assembling Ikea Metod Cabinets Precisely and Securely Against Sloped Walls
Created on: 19 Dec 2015 08:22
raizak60
Hello everyone, I am currently planning the setup of our new kitchen using Ikea Metod cabinets. However, I have the issue that the walls are slanted because we live under a pitched roof. My question is: how can I install the Metod cabinets precisely and securely against such slanted walls? Are there proven methods or special techniques to avoid gaps and unstable constructions? I would like to learn how to fit the cabinets as accurately as possible to the sloped wall without losing stability, and which materials or additional parts are recommended for this. I’m also interested in the best way to secure the cabinets to the sloping roof. Thank you very much for your tips and experiences!
Midra
19 Dec 2015 12:13
Doors are indeed critical when dealing with sloped walls. I recommend using door hinges that can be adjusted on multiple axes. The Ikea Metod hinges often allow a generous range of adjustment, which helps.
Wood strips as a substructure can easily correct angles up to about 10° to 15° when done carefully. For steeper slopes, as mentioned, a wooden frame substructure is advisable to raise the cabinets to a level surface.
Additionally, filler pieces made of MDF or strips can be used between the cabinet and the sloping ceiling. These are not load-bearing but visually close the gap.
It is important to choose fastening points in solid areas—so not just drywall with standard wall plugs, but rather supporting beams or appropriate fasteners.
O
ONCARTER
20 Dec 2015 08:43
Additionally, I would like to add that the stability of Metod cabinets installed under sloped ceilings largely depends on how the cabinets are anchored to the load-bearing wall or ceiling. The typical back panels made of hardboard do not provide sufficient load capacity.
To install the cabinets at an angle, I recommend the following steps:
- Determine the exact angle of the slope using a digital angle finder.
- Construct a subframe from wooden battens to position the cabinet on a flat, level surface. These battens should be securely fastened to the wall.
- Use angled trim strips to minimize visible gaps.
- For securing the cabinets to the wall, heavy-duty anchors should be used; for drywall stud walls, special hollow wall anchors are necessary.
This approach maintains load-bearing capacity, keeps the doors aligned, and ensures proper load distribution.
The sequence of work is also important: first the subframe, then the cabinet installation, followed by trim and finishing strips.
This method ensures both precision fit and stability.
BLAKEO
20 Dec 2015 09:17
ONCARTER schrieb:
Additionally, I would like to add that the stability of Metod cabinets on sloped ceilings largely depends on how securely the cabinets are fastened to the load-bearing wall or ceiling.
Exactly. I would like to add that for very steep slopes, it can be worth considering two-part cabinet solutions, where the upper section, possibly with compartments or open shelves, follows the slope, while a traditional cabinet base stands below.
This approach makes it easier to manage both stability and functionality. Cabinets that are entirely tilted always carry some risk regarding the load-bearing capacity of their joints.
Does anyone have experience with whether such partial solutions (e.g., an open shelf above a cabinet) are practical and durable in real-life use?
