ᐅ Are solid wood walls possible in a timber-frame house?
Created on: 10 Oct 2020 23:07
MiCasaEsSuCasa
Good evening everyone!
We are currently planning our house (still just in our minds at the moment, but hopefully soon officially). I am wondering if it is possible to build some walls from wood in a solid masonry house. Partly for cost reasons, but not only that.
Thanks in advance for your answers!
Pinky030111 Oct 2020 16:38
We often watch American remodeling shows and wondered why they use wooden battens instead of metal studs. Our research showed that wood has the disadvantage of warping or shrinking. Also, it is more expensive than metal studs (or metal profiles) in our country. What are the drawbacks of traditional drywall partitions? Or am I misunderstanding, and you actually want to build the entire wall out of wood?
MiCasaEsSuCasa
11 Oct 2020 16:44
Haha, we also really enjoy watching those shows and have gotten inspired by them.
It definitely does not have to be made of wood. I just thought that would be the most affordable option. In that case, such walls wouldn’t be made of stone but rather from those metal studs/profiles, right?
11 Oct 2020 17:09
MiCasaEsSuCasa schrieb:
Oh, we wouldn’t actually find that bothersome. More like cozy.
We’re just wondering whether it would be better, more practical, or cheaper to have such “non-essential,” non-load-bearing walls built from wood.
This will be determined later during the planning phase, depending on whether and how the walls are constructed. The floor plan is coordinated with the structural engineering, and the most efficient materials are selected accordingly. For a recess in a load-bearing wall area, you would typically use a masonry wall rather than wood with a beam. The roof also requires load-bearing supports. ...
Bulkheads, lightweight partition walls, and platforms are generally made using panel construction.
So, scribbling on your DIY plan now might be a way to pass the time, but this is the job of a professional.
MiCasaEsSuCasa
11 Oct 2020 17:33
All right. Interesting. We don’t know any of that.
KingJulien11 Oct 2020 18:31
So, for what you want, there are several options.
  • Drywall (gypsum boards on wooden or metal studs)
  • Solid wood walls, for example from a carpenter
  • Ytong blocks (aerated concrete blocks), etc.
But it doesn’t sound like you want to do it yourselves, right?
Then just freely draw what you have in mind and discuss the best implementation with your general contractor / main contractor / architect.
Depending on the desired appearance and use, many solutions can make sense.
haydee
11 Oct 2020 19:33
Corners are often inconvenient and not cozy. You also need to be able to furnish the area next to the built-in wardrobe.
