ᐅ Are there options to expand or customize the Ikea BESTA modular system?
Created on: 13 Nov 2016 18:37
TanroHello everyone,
I’m currently looking into the Ikea Besta system, especially regarding its modularity and possible expansions. My main question is: Are there practical and stable ways to expand the Ikea BESTA system modularly, meaning to enlarge or restructure it beyond the standard configurations in a custom way? I’m not just talking about placing extra cabinets side by side, but also about integrative expansions—for example, suitable extension kits, custom-built additions, or other clever solutions that fit seamlessly.
I’m looking for experience, ideas, or tips on how to make the BESTA system larger for purposes like wall units, media setups, or simply more functional designs, without compromising stability or aesthetics. Are there official or unofficial modules, hinge adjustments, reinforcements, or anything similar?
Thanks and best regards!
Hey Tanro!
It’s great that you’re exploring the BESTA system in more detail – it’s really impressively flexible! 😊
To answer your question: Yes, BESTA can definitely be expanded and modified in a modular way. Many people here in the forum have, for example, combined different carcasses that can be mixed in height and width.
- Many add extra shelves or change the position of the adjustable shelves.
- There are also clever hacks with additional brackets to connect multiple modules, ensuring everything stays stable.
However, it’s important to pay attention to the load capacity, especially if you build the furniture higher or join it at the corners.
It’s a lot of fun and definitely doable! If you like, I can send you some examples from my living room. 👌
Johnathon14 Nov 2016 08:46Pome60 schrieb:
It is important, however, to consider the load-bearing capacity, especially if you build the furniture taller or join it at an angle.That is exactly the key point that should not be underestimated. I have personally expanded a BESTA system modularly and have gathered the following experiences:
- For stable connections between the cabinets, I use metal strips or special corner connectors from third-party suppliers.
- Ikea’s plug-in system is basically designed for a certain level of modularity, but when building taller structures, you often need to reinforce the back panels additionally.
- For larger wall units, it is advisable to attach the individual modules to the wall rather than relying solely on the cabinet connections.
- When modifying the doors, keep in mind that hinges are not infinitely flexible – sometimes special adjustments for damping or closing mechanisms are necessary.
I am curious about the exact application you are planning. Should the system mainly serve an aesthetic purpose, or does it require specific technical features (e.g., cable management for media devices)?
Johnathon schrieb:
I’m curious about the details of your planned application. Is the system mainly meant to have a visual impact, or does it need specific technical features (e.g., cable management for media devices)?Good question, Johnathon!
My goal is actually to design a modular living wall that is visually flexible, offering different heights and depths, but also functional, especially for media and storage. The system should be expandable so that I can, for example, add extra cable pass-throughs and possibly retrofit modules with specific features like built-in power outlets or lighting.
Stability is obviously important—I want to use as little additional material as possible beyond the Ikea accessories, but if more is needed to enhance modularity, that’s of course acceptable.
In your experience, are there simple solutions or even specially designed extensions for this? Has anyone here carried out similar projects?
Tanro schrieb:
Stability is obviously important – I want to use as little additional material as possible besides the Ikea accessories, but if it’s necessary to increase modularity, then of course more is needed.Hey, you’re bringing up a great point! 😄
I really like the Ikea BESTÅ system as well because it’s truly easy to customize.
- If you need cable openings, you can either carefully cut out the back panel where needed—careful though, or you’ll lose stability—or use the perforated plastic back panels that sometimes come with the furniture.
- For integrated lighting, there are LED strips that are easy to install and some even come with remote controls.
- I haven’t personally seen power outlet modules, but there are clever inserts that can be used as intermediate shelves where you can retrofit outlets.
The same goes for brackets in my experience: you can generally work quite well with Ikea’s own accessories if you do a bit of DIY. And yes, always secure everything properly so it doesn’t get wobbly.
Good luck, Tanro! Try a small extension first before doing a major rebuild—that way you can get to know the furniture system perfectly.
