I am looking for inspiring and practical upcycling ideas specifically for IKEA Hemnes furniture. I am interested in how these popular pieces can be easily customized or redesigned due to their classic construction and materials, giving them a unique character while also acting sustainably. For example, I am wondering if it is possible to modify doors and drawers with simple methods that don’t require much expertise in furniture making. Does anyone have experience or detailed tips on how to turn Hemnes dressers, beds, or shelves into real eye-catchers with minimal effort and basic materials? I am also interested in topics such as wood treatment, surface finishing, or subtle additions. I’m looking forward to your suggestions and would appreciate practical advice.
Peoti61 schrieb:
I’m interested in how these popular pieces of furniture, due to their classic construction and materials, can be easily customized or redesigned to give them a unique character while also being sustainable.This idea immediately caught my attention: Hemnes furniture is often made of solid pine, which is great for sanding down and repainting. I once painted a dresser completely white and finished it with a wax coating — it looks like a designer piece.
- Replace doors or cover them with wallpaper for a vintage look
- Swap the handles for antique brass knobs
- And for something more unusual: unscrew the legs and replace them with pipes to create an industrial style
You can really achieve a great effect with relatively little effort. It’s sustainable, too, since you’re not buying new furniture. 😉
Hemnes is particularly well suited for upcycling due to its solid timber construction. It is important to first check the condition of the wood and, if necessary, sand it before applying any surface treatment.
Using natural oils or waxes is recommended to preserve the wood’s texture. Alternatively, water-based paints can be used to maintain the character while adding color. For doors and drawers, self-adhesive foil or veneer can be experimented with, but adhesion should be carefully tested.
In addition, modifying the fittings is an easy way to create a fresh look without damaging the piece of furniture.
PULAU schrieb:
For doors and drawers, you can experiment with self-adhesive film or veneer, but the adhesion should be carefully tested.I agree with you. Additionally, I would say that surface preparation is crucial: remove any chips beforehand, lightly roughen the surface with fine sandpaper, then the adhesive will stick better.
There are also various upcycling options for Hemnes furniture:
- Converting drawers into small shelves
- Redesigning bed frames with fabric upholstery
- Replacing shelves with colorful inserts
All of these are definitely doable even for beginners, as long as a bit of patience is brought along.
LUKO45 schrieb:
Replacing doors or covering them with wallpaper for a vintage lookHow problematic do you think it is to apply wallpaper to Hemnes wood? I'm especially interested in the durability and the risk of peeling. Does the surface require special preparation, or is it possible that the wallpaper might come off after just a few months?
Katau schrieb:
Remove any chips beforehand, lightly sand with fine-grit sandpaper, then it will adhere better.Thanks for the tip—that sounds like good preparation! Which types of adhesive are best suited for wallpaper on wood? I want to avoid anything that could leave residue or cause damage later on.
