ᐅ Are there any upcycling ideas for IKEA Hemnes furniture?
Created on: 18 Dec 2015 08:23
Peoti61
I am looking for inspiring and practical upcycling ideas specifically for IKEA Hemnes furniture. I am interested in how these popular pieces can be easily customized or redesigned due to their classic construction and materials, giving them a unique character while also acting sustainably. For example, I am wondering if it is possible to modify doors and drawers with simple methods that don’t require much expertise in furniture making. Does anyone have experience or detailed tips on how to turn Hemnes dressers, beds, or shelves into real eye-catchers with minimal effort and basic materials? I am also interested in topics such as wood treatment, surface finishing, or subtle additions. I’m looking forward to your suggestions and would appreciate practical advice.
O
ONCARTER
20 Dec 2015 12:37
Peoti61 schrieb:
How problematic do you consider wallpaper adhesion on Hemnes wood?
The adhesion of wallpaper on treated wooden surfaces like Hemnes can vary. The surface needs to be thoroughly cleaned and only lightly sanded to improve adhesive bonding. Wallpaper paste or special adhesives designed for wood are best, as they tend to be fairly flexible and moisture-resistant. Solvent-free adhesives are recommended to protect the material.
Peoti61 schrieb:
Does the substrate require special preparation, or is it likely that the wallpaper will come off after just a few months?
If you sand the surface properly, clean it well, and use a suitable adhesive, the wallpaper should hold permanently. However, with heavy use, such as frequent opening and closing of furniture doors, the wallpaper edges might become worn or start to peel. In such cases, sealing the edges can help—using clear varnish or transparent tape on the inside, for example.
This can give the furniture an interesting look but is generally recommended for decorative wall surfaces rather than highly stressed areas.
Tobias
21 Dec 2015 08:16
Simply unscrew the doors, sand them down, paint them, and install new handles. For drawers, you can cut an organizer with small compartments. Easy to do and quickly changes the look.
LUKO45
21 Dec 2015 19:05
Peoti61 schrieb:
How problematic do you consider wallpapering on Hemnes wood? I’m especially interested in the durability and the risk of it peeling off.
Peeling usually occurs when moisture is involved or if the adhesive wasn’t applied properly. Always keep the wooden surface completely dry—that’s already half the battle! Otherwise, a thin layer of repair filler can help smooth out any unevenness before applying the wallpaper.
Peoti61 schrieb:
Does the surface need special preparation, or is it likely that it will start coming off after a few months?
Yes, preparation is key. But if you do that, it often lasts for years—and if not, you can always redo it. A bit of upcycling always involves some experimentation, and Hemnes gives you a good base for that. Good luck!
