ᐅ Are there any tips for simple repairs on Malm furniture?
Created on: 8 May 2024 13:27
talhamo56
talhamo56
8 May 2024 13:27
I have a small issue with my IKEA Malm furniture, which is quite common in everyday use. I’m interested to know if you have any specific tips or tricks for simple repairs that can be done yourself without much specialized tools.
I’m mainly concerned with minor problems like light scratches, loose screws, misaligned drawers, or swollen spots caused by moisture. Unfortunately, I often find only very general advice or recommendations to visit professional workshops, which is too complicated for me.
Are there any proven methods, materials, or even DIY hacks that can quickly restore Malm furniture without starting a major repair process?
Thanks in advance for your help!
V
vin_leo
8 May 2024 14:03
talhamo56 schrieb:
Are there any proven methods, materials, or maybe even DIY hacks to quickly restore Malm furniture to good condition?
Sure, there are a few easy tricks! For scratches, wax sticks or furniture polish work wonders – the colors often match the wood tone, and a little buffing afterward makes it look almost like new.
If drawers stick, check that the runners are securely in place and a bit of silicone spray can work like magic. Loose screws? Wood glue and some wooden dowels can also fix that nicely.
And the classic issue with moisture: let it dry thoroughly first, then gently sand with fine sandpaper and treat with varnish. All very DIY-friendly and usually with items you already have around 😉
Good luck pimping your furniture! 🙂
fredle
9 May 2024 09:38
Here is a brief guide to common issues with Malm furniture:
1. Removing scratches: It’s best to use special furniture wax sticks matched to the color. Apply them thinly to the scratch, let them dry briefly, then polish with a soft cloth.
2. Loose screws or wobbly drawers can often be fixed by completely unscrewing the screw, filling the hole with some wood filler or wood glue. Once dry, screw the screw back in. This ensures a firm hold.
3. Drawers that catch or stick usually benefit from cleaning the runners. Use a vacuum cleaner first, then apply some silicone spray, which lubricates without becoming sticky.
4. Areas swollen from moisture should be lightly sanded first and then protected with a thin layer of clear varnish (for example, acrylic varnish). This prevents further moisture penetration.
The most important thing: take your time and work step by step. If you use the proper materials, repairs often last a long time. And for surface damage, testing in an inconspicuous spot is always recommended.
I hope this helps you! 🙂
neoren
10 May 2024 11:17
fredle schrieb:
Drawers that stick or jam usually benefit from cleaning the drawer slides
If the drawer slides are bent, gently bend them back by hand—this usually helps.
vin_leo schrieb:
For scratches, wax sticks can help, for example
Wax sticks or furniture markers, depending on what you have available. Important: Match the color tone beforehand!
One more tip for loose wood: apply wood glue in the screw hole and use slightly thicker or longer screws for a better grip.
