ᐅ Are there any special tools required for assembling Ikea Metod cabinets?
Created on: 7 Sep 2024 08:32
Damien36
Damien36
7 Sep 2024 08:32
I am planning to assemble several Ikea Metod kitchen cabinets soon and was wondering if there are any special tools that make the assembly easier or even necessary.
Ikea usually provides an Allen key, but the assembly sometimes feels a bit fiddly, especially with the screws and dowels.
Are there any professional tools or practical gadgets you would recommend? If so, which tools are truly useful for assembling the Metod series to save time and effort?
Looking forward to your experiences and tips!
GALEO4
7 Sep 2024 09:17
Interesting question! Whether special tools are truly necessary for assembling Ikea Metod cabinets largely depends, in my opinion, on how ambitious you want to be during the build.
Damien36 schrieb:
Ikea basically includes an Allen key, but the assembly can be a bit fiddly at times
That’s exactly the point: Ikea keeps the self-assembly requirements low, so they hardly provide any specialized tools themselves. However, the quality of the included tools is critical—they are often minimal tools that barely get the job done. If you want to work more professionally, you should definitely invest in better screwdrivers or a cordless drill.
I would even say that every Ikea assembly can be done with basic tools, but comfort increases exponentially with investing in good tools. So why not use a suitable right-angle bit attachment for the cordless drill instead of struggling with the tiny Allen key?
juMira46
7 Sep 2024 10:05
Good morning! I always find it funny how Ikea first gives you a tiny Allen key and then expects us to be real DIY experts 😄
But seriously:
- A cordless drill with a suitable bit set is really invaluable.
- A ratchet with an Allen bit also makes screwing much easier.
- And it’s a good idea to have a small rubber mallet on hand, especially when the wall plugs (anchors) don’t want to fit easily.
These tools make assembly much more relaxed. Of course, you don’t need the whole toolbox, but with a few extras, it’s more enjoyable and goes faster.
So if you plan to assemble furniture more often, I’d recommend investing in some good basic tools. 😉
fredle
7 Sep 2024 11:24
Hello Damien36,
Here are some practical tools for assembling Ikea Metod cabinets that I often use myself:
- Cordless screwdriver with a set of precisely fitting hex bits (usually 4mm (5/32 inch) for the Metod screws)
- There is also a right-angle attachment available, which is helpful for accessing tight spaces
- A rubber mallet, as juMira46 mentioned, to gently tap in the dowels without damaging the material
- A bit of patience to ensure the parts fit together properly!
Important: Ikea often provides self-tapping screws, so make sure to screw in slowly and carefully to avoid damaging the threads.
If you work without a cordless screwdriver, the included hex key is quite tight and intended more for occasional screwing rather than the entire assembly process.
My advice: Gather all your tools before starting, and test the driver bits on one screw first—this way, you’re prepared for everything.
Fitigu
7 Sep 2024 13:46
Regarding the question of whether special tools are required for assembling Ikea Metod cabinets: fundamentally, no exclusive tools are needed. The assembly is designed for standard tools.
- A mini Allen key is included
- A cordless drill with the appropriate bits significantly speeds up the work and reduces physical effort
- A rubber mallet can be helpful when inserting wooden dowels
- A spirit level is recommended for proper alignment
Professional assembly teams often use angle attachments for the cordless drill to reach difficult spots.
Conclusion: Assembly is straightforward with standard tools plus a few useful accessories.
SETHBLA
8 Sep 2024 07:12
Additional tools: cordless screwdriver with hex bits, rubber mallet, and spirit level. Nothing else special is required.
