ᐅ Are there specific durability tests conducted for IKEA Platsa furniture?
Created on: 10 Jan 2016 13:44
figo1
figo1
10 Jan 2016 13:44
I am planning to purchase the IKEA Platsa system and am wondering if there are any specific durability tests for this furniture series. In particular, I am interested in whether IKEA itself or independent testers evaluate how durable and robust the individual modules are under everyday use. Are there standardized testing procedures applied specifically to Platsa, such as load, wear, or stability tests? More details about the testing methods or any information on how customer reviews reflect these aspects would be very helpful. Thanks in advance!
Merlin
10 Jan 2016 14:12
IKEA carries out all the standard load tests for Platsa systems that comply with furniture standards. However, no specific durability tests are publicly known. The modules are sturdy enough for normal household use.
FABIAN_DEO
11 Jan 2016 09:35
Merlin schrieb:
IKEA performs all the standard load tests for Platsa systems that meet furniture industry standards.
That is generally correct, but it’s worth taking a closer look at what the “standard load tests” actually involve. IKEA mostly follows standards such as EN 16122 for modular furniture, which include tests for static load, dynamic stress, and tipping resistance. For Platsa, this means that individual components, connectors, and surfaces must withstand a defined minimum load before any damage occurs.
In addition, manufacturers like IKEA conduct so-called durability tests, simulating frequent movements (such as opening doors and drawers) tens of thousands of times. However, these tests are not specific to Platsa but apply more broadly to modular furniture.
If you plan to use the furniture for specific applications (e.g., heavy loads in commercial settings), it would be helpful to know the intensity with which you expect to use the furniture.
Do you already have experience with the material thickness or the weight capacity of the Platsa modules that you are particularly interested in? That would help to provide a more precise assessment.
RUBEN54
12 Jan 2016 17:03
figo1 schrieb:
whether there are specific durability tests for this furniture series
A good question, especially if you see furniture not just as a short-term solution but want to use it long-term.
Here is a brief overview of how the durability of furniture like Platsa is usually tested:
- Static load tests: Checking if the furniture can consistently support the specified weight, for example, load on shelves.
- Dynamic tests: Simulating frequent use, mainly opening and closing doors and drawers.
- Moisture tests: Assessing how the material reacts to humidity, important for wood-based materials.
- Joint and stability tests: Verifying whether screws and connectors remain secure after extended use.
IKEA rarely provides detailed information about specific tests for Platsa, but it is assumed that their standards in these areas are met. This suggests a reasonable durability for home use.
I also recommend reading customer reviews and long-term user experiences to get practical opinions on durability. It is important to assemble the furniture carefully and follow the instructions, as mistakes during assembly can significantly affect its lifespan.
