ᐅ Are there any issues with using Ikea Hemnes furniture in a damp basement?
Created on: 1 Mar 2015 10:13
LenbarHello everyone, I have a question that some of you have probably encountered before: Are there any issues with Ikea Hemnes furniture when used in a damp basement? I am planning to set up some shelves and cabinets from the Hemnes series there, but I am unsure how the solid wood and finishes will hold up under the typical moisture conditions found in basements. Could this lead to swelling, warping, or even mold growth? And what measures would be advisable to minimize potential damage? I look forward to your experiences and insights on this topic.
Basically, Hemnes is a solid wood piece of furniture that can react sensitively to moisture due to its material characteristics. In damp basement rooms, there is a definite risk of swelling, warping, or even mold growth. I recommend checking the following points in advance:
- Measure the humidity with a hygrometer; ideally below 60%.
- Ensure sufficient air circulation, possibly using a dehumidifier.
- Place the furniture elevated on feet or wooden slats to avoid direct contact with the floor.
- Treat visibly open-pored surfaces with wood protection oil or varnish to reduce moisture absorption.
In summary: Hemnes furniture is not ideal for damp basements but can be used with proper preventive measures.
Thanks for the feedback so far!
@Sepele: Very helpful tips. I’d like to know if the Hemnes surfaces are specifically treated to provide some moisture resistance on the surface, or if it’s basically untreated wood coated only with varnish?
It would also be interesting to hear if anyone has long-term experience—like several years of use under basement-like conditions?
The humidity in my place varies seasonally between about 55% and 70%.
Hello Lenbar, I’m happy to answer your questions: Hemnes is made of pine wood that is lightly lacquered – the surface is sealed with clear varnish, which provides some protection against moisture but is not completely waterproof. Over time, moisture can still penetrate the wood and affect its structure. Based on my own experience and feedback from many users over several years, I can say that Hemnes furniture in damp basements usually starts to show problems after 1-3 years if no precautions are taken. These include slight swelling, minor warping of doors or drawers, and occasionally discoloration. Therefore, it is definitely important to maintain sufficient distance from the floor, ensure air circulation, and, if necessary, use an additional dehumidifier in the room. It also helps to check the furniture regularly and take early action if any damage signs appear.
