ᐅ Are there more durable alternatives to the standard Billy shelves?
Created on: 25 Jul 2022 18:23
itay30
itay30
25 Jul 2022 18:23
I am currently planning my new home office and, besides a desk, I want to use shelves mainly for books and folders. The Billy shelves from IKEA are quite standard and found in many households. However, I have noticed that the standard Billy shelves often bend or permanently sag under heavier loads – especially when fully stocked with heavy encyclopedias or archives.
I am therefore interested in whether there are more load-bearing alternatives to the typical Billy shelves that I can either buy directly as replacements or possibly adapt myself. Ideally, they should have a higher load capacity but not significantly increase in price or complexity when it comes to assembly.
Do you have specific recommendations or personal experiences with alternative shelves, materials, or maybe tips on how to significantly improve the load capacity of Billy shelves? Which brands or solutions have proven reliable, and what should one definitely consider when choosing?
Thanks for your opinions and tips!
BARSAN
25 Jul 2022 19:07
Instead, I use multiplex plywood shelves, which are more stable and can support heavy loads well. They are more affordable than specialized shelving from furniture manufacturers. Just have them cut to size.
tyson51
25 Jul 2022 20:52
Hello itay30,
In general, it can be noted that the standard Billy shelves made of particleboard with a thin veneer layer are designed for light to medium loads but may bend under high weight.
As an alternative, I recommend solid wood panels or plywood boards with a thickness of at least 18 mm (0.7 inches). These are significantly more durable and stronger. Additionally, support for the shelves should be provided by additional center or back panels.
A often underestimated tip: shelves can also be reinforced by installing supports or small crossbars underneath to reduce the span length.
Overall, it is worthwhile to pay attention to wood quality and moisture resistance, especially when carrying heavier loads. Stores like Hornbach or Obi offer good cut-to-size options at reasonable prices.
Compared to the original Billy material, these solutions are usually more robust but also somewhat more expensive.
angel
26 Jul 2022 08:35
Hello itay30,
your question is very well formulated and addresses a concern shared by many Billy shelf users. While the Billy shelves are affordable and practical, the load-bearing capacity of the standard shelves is indeed limited.
In addition to the previously mentioned plywood or solid wood boards, shelves made of MDF (medium-density fiberboard) are also an option, as they often have a higher density than particleboard and are more stable. It is also possible to use MDF boards with special coatings, which are more durable and easier to maintain.
If you are handy or know someone who can help, sometimes installing metal reinforcements or adding center supports to the Billy shelves is recommended. This can significantly increase the load capacity without noticeably changing the appearance.
One important note: check whether your shelf is actually sagging due to the material being too thin, or if the shelf brackets or mounting are not properly adjusted. Incorrect installation can also cause instability.
Best regards and good luck with your project!
chen67
26 Jul 2022 14:19
Hi itay30,
I have to say, I’ve often thought about shelf boards bending when Billy bookcases are fully loaded. 🙂 My DIY solution: I simply replaced the original shelves with 22 mm (just under 1 inch) thick multiplex plywood boards and added small metal brackets underneath the shelves. This basically gives the shelf a “power-up.”
tyson51 schrieb:
A often underestimated tip: You can reinforce shelves by installing support beams or small crossbars underneath the boards to reduce the span.
I completely agree with that.
Also, if the shelves will be permanently loaded with heavy weight, I would recommend using solid wood rather than particle board. It just feels more stable when you touch the boards. Plus: it costs a bit more, but your shelf won’t creak and you won’t have to worry when it’s fully loaded.
Cheers 🙂
GALENKU
27 Jul 2022 10:41
I have had good experiences with shelves made from beech plywood panels. At a thickness of 18 mm (0.7 inches), they are strong and hardly warp.
If the budget allows, it is best to have the shelves custom-made on site. It is important to have good edge sealing to prevent water or moisture from penetrating.
Alternatively, there are special metal shelves or steel constructions, but these are a completely different level in terms of style and complexity. For everyday use, wooden boards with properly glued additional supports are usually the best choice.
