ᐅ Are there Ikea PAX wardrobes available with extra tall shelves?
Created on: 21 Jul 2022 08:37
ELJESUSGood morning everyone,
I am currently looking into purchasing an Ikea Pax wardrobe system for my bedroom and have come across a question I would like to discuss here: Are there Ikea Pax wardrobes with particularly tall shelves or shelf heights, meaning higher than the standard shelf levels, to accommodate larger or bulkier items?
So far, I have only seen the typical shelf heights spaced roughly every 30 to 40 cm (12 to 16 inches), but for my needs, it would be important to know if there are versions with significantly larger spacing or if there are options like special solutions or shelf extensions available.
Perhaps someone has experience with either officially taller shelves from Ikea or modifications they have made themselves. I would be very grateful for any advice on dimensions, available products, or general tips!
Leonardteo21 Jul 2022 09:12Hello,
regarding your question: Ikea Pax typically comes with shelves about 39 cm (15 inches) high, that’s correct. However, there are two important points: First, the shelves are adjustable, so you can place them freely into the existing rows of holes – the spacing can vary as long as the unit has flexible holes. Second, Ikea also sells shelving boards in different heights and depths, including tall side panels or special clothes rails as an alternative to shelves.
Some users also report custom solutions, such as removing shelves or installing larger boards outside the standard product range. However, these are more individual modifications rather than official product options.
For reference:
- Ikea PAX offers a selection of shelves and clothes rails that can be purchased individually.
- The shelves can be adjusted in increments of approximately 3 cm (1 inch), allowing for flexible customization.
- For especially tall compartments, it is common to remove individual shelves completely to increase vertical space.
A tip: Check the maximum load capacity of the shelves and the overall stability during your planning. There are also accessories available, such as additional support rods, if you need to store heavier items.
If you like, I can provide a brief guide on the optimal configuration of the PAX units.
Leonardteo schrieb:
Ikea Pax typically comes with shelves about 39 cm (15 inches) high by default, that’s correct. However, there are two important points: First, the shelves are adjustable, so you can position them anywhere along the existing rows of holes – the spacing can vary as long as the frame has flexible hole patterns.Thank you for the detailed response, Leonardteo. I wanted to add that I am specifically planning for a shelf width of 50 cm (20 inches) per shelf board, and the cabinet height is about 236 cm (93 inches), which is the standard Pax height. Within this framework, I am looking for something that goes beyond the standard shelf height, meaning shelves with more than 39 cm (15 inches) of vertical space, especially for bulky items like larger suitcases or thick books.
What about the height options for Pax? Are there taller frames available, or any accessories that allow you to effectively build the wardrobe higher, such as extension frames or additional boxes?
