ᐅ Are there Ikea Pax wardrobes with especially high load capacity?
Created on: 2 Dec 2017 08:13
Kuusneo
Kuusneo
2 Dec 2017 08:13
I am interested in the Ikea Pax furniture system and am specifically looking for wardrobe solutions with particularly high load capacity. My question is: Are there versions or special designs within the Ikea Pax range that offer above-average weight-bearing capabilities, for example, to hold very heavy clothing, a large number of shoes, or even for use as storage for heavy items?
I am also interested in details such as the maximum load ratings for shelves, the sides of the wardrobe, or any additional reinforcements that Ikea officially offers or that you would recommend based on your experience.
Thanks in advance for your insights and recommendations!
REN40
2 Dec 2017 09:32
Hello Kuusneo,
Ikea PAX wardrobes are generally designed for typical household use and offer solid load capacity. Individual shelves usually support up to about 25 kg (55 lbs), which is sufficient for clothes and shoes.
What you refer to as "especially high load capacity" could potentially be achieved by adding reinforcements. Ikea does not offer official product variants with higher load ratings, but it is possible to increase the load capacity by adding shelves made of thicker material or by installing metal supports.
Proper assembly and securing the unit to the wall are important, as stability otherwise suffers. If you need exact values for specific components, you can check the manual, where load limits are provided.
Nicksin
2 Dec 2017 10:47
REN40 schrieb:
The individual shelves usually support up to about 25 kg (55 lbs)
That already sounds like a solid baseline! 😎
I would add this: If you want to use the cabinet as a load-bearing storage, you could simply distribute the shelves cleverly and, for example, place the heavier items as close as possible to the supporting sides. This way, the whole structure can definitely hold even more.
And hey, with IKEA furniture, you always have that DIY charm – reinforce a bit yourself, and voilà, your own high-load edition! 😉
TEBILO
2 Dec 2017 13:28
Hello Kuusneo,
I would like to go into a bit more detail, as the topic of high load capacity for Ikea Pax cabinets involves some interesting technical aspects.
First: The load limits of the shelves generally range between 20 and 30 kg (44 and 66 lbs), depending on the material used. The shelves are mostly made of particleboard with a thin melamine coating, which can bend under excessive weight.
Second: The side panels are also relatively thin, making longitudinal reinforcement difficult. This means that a high load in the middle of a shelf without proper reinforcement can cause the sides to bend.
Third: Ikea does not offer official reinforced shelves for Pax, but the load capacity can be significantly increased by installing a metal bar or aluminum profiles underneath the shelves in the center.
Fourth: For very heavy loads, it may be worthwhile to consider using a completely freestanding shelving system with a stronger construction. Pax is recommended to be fixed to the wall to prevent tipping and to stabilize the sides.
I am curious about your exact use case: Do you plan to store shoes, clothing, tools, books, or even machinery? This will best determine the type of reinforcement needed. Perhaps you can provide more details?
Kuusneo
3 Dec 2017 07:56
TEBILO schrieb:
I’m curious about the exact intended use: Will shoes, clothing, tools, books, or even machines be stored? This best determines the type of reinforcement needed.
Good question, thanks!
Basically, it’s about clothing and shoes, which increases the load per shelf but probably not to an unusually heavy level. However, I plan to store heavy winter boots, several bags, and some thicker jackets hanging on sturdy clothing rods.
Additionally, I want to keep boxes with higher weight (up to 15 kg (33 lbs) per box) in some compartments, which raises the floor load.
I’m also interested in the stability of the clothing rods themselves and their brackets.
In summary: I’m looking for a combination offering maximum load capacity for shelves, side panels, and rods without having to buy an entirely different system.
O
olivernu
3 Dec 2017 09:18
regarding your question, the Pax wardrobe rods are generally rated to hold up to 15 kg (33 lbs). If overloaded, the brackets may bend.
So, if you are hanging several winter coats, you should consider the weight on the rod. Ikea also offers accessories that allow you to support the rods in the middle—an option if you plan to store many heavy garments.
For the shelves, I can confirm that the maximum load is about 25 kg (55 lbs). Beyond that, it is advisable to distribute the weight evenly or install additional reinforcement.
Wall mounting is mandatory here to ensure stability.
