ᐅ Are there any useful tools for assembling Ikea PLATSA furniture systems?
Created on: 19 Oct 2023 08:27
JebarHello everyone,
I am currently facing the challenge of assembling an Ikea PLATSA furniture system and wonder if there are any helpful tools or accessories that can make the assembly process more efficient or easier.
I am familiar with standard tools like screwdrivers and cordless drills, but are there any special tools that work particularly well with PLATSA? Perhaps tools that facilitate the assembly of the wooden parts or connectors, or practical tips for handling the various components?
I am especially interested in whether there are tools that prevent common issues during assembly or improve stability and accuracy when putting it together.
I would greatly appreciate any feedback, recommendations, or personal experiences with PLATSA—also any hints on which accessories really make a noticeable difference.
A good cordless screwdriver with torque control can help prevent over-tightening screws when working with PLATSA.
I also recommend a small hammer or rubber mallet to gently fit wooden parts together.
A carpenter’s square or angle measurer is useful to ensure everything stays square.
Your question about using helpful tools when assembling a PLATSA furniture system is very relevant, and I would like to explain the procedure in more detail. Basically, PLATSA follows the typical Ikea assembly steps and is fairly intuitive, but there are some tools and tips that can make the process much easier and the result more stable.
First, using a cordless drill/driver with adjustable torque is recommended to drive the screws evenly without over-tightening. Many users find a small set of hex keys (Allen wrenches) in various sizes very useful, especially since some connections are hard to reach with larger tools.
Additionally, a plastic or rubber mallet can help with assembling dowels or connector caps without damaging the surface.
A small trick I use is to lightly lubricate all plastic connectors (especially the so-called "cam" connectors) with silicone oil or wax beforehand. This makes connecting easier and the locking noticeably smoother.
It is also important to have a stable work surface to avoid any warping—since PLATSA is modular and flexible, uneven assembly can lead to instability over time.
Do you already have experience with similar Ikea furniture? What tools do you currently have? That way, I could offer more targeted advice, including about any additional tools you might consider getting.
Oh yes, PLATSA is really fun, but without the right tools, it can be quite frustrating! 🙂
When I was assembling mine, I noticed that a small rubber mallet works wonders – you can fit the parts together perfectly without risking scratches.
And what I highly recommend is a small spirit level or a protractor, so that everything ends up standing straight. Otherwise, you’ll have crooked cabinets afterward, and that can be annoying over and over again!
Good luck, you can do it, and with the right aids, it will be much easier.
Regarding the question about useful tools for assembling Ikea PLATSA, I can provide the following precise technical recommendations:
- A cordless drill with adjustable torque control and a suitable bit set (preferably Torx and Phillips) is essential for correctly tightening the connector screws and avoiding damage to the materials.
- In addition to common hand tools, a protractor or angle finder is recommended to reduce assembly inaccuracies.
- A small rubber mallet can be used to insert the corner connectors (“cam locks”) without damaging the materials.
- It is also advisable to check the components for proper fit beforehand, as applying force should be avoided whenever possible.
This combination of tools significantly improves both efficiency and the stability of the finished furniture.
An important note: The PLATSA modules are modular and can be customized individually. Therefore, it is wise to have all plans and tools ready before starting assembly to ensure a smooth workflow.
barle schrieb:
A protractor is also useful to ensure everything stays square. Interesting tip, but I wonder if the effort is really worth it with a system like PLATSA, which is designed for straightforward self-assembly.
In my opinion, most of the additional tools you might use are overkill for this kind of flat-pack furniture. Maybe you can simply rely on the precision fit of the IKEA parts and avoid using highly professional equipment?
What do you think? Does every piece of furniture need to be measured that accurately, or is that more something for professionals or larger pieces?
