ᐅ Are there heat-resistant adhesive films available for the KALLAX?
Created on: 20 Jun 2016 13:17
pagodi
I am planning to cover my KALLAX shelf with adhesive film because I want to change its appearance a bit. However, the film needs to be heat-resistant since I occasionally store items there that can emit heat, such as candles or small electronic devices. My question is: Are there heat-resistant adhesive films generally suitable for use on a KALLAX shelf? And if so, does anyone have experience with such films regarding adhesion strength, durability, and temperature tolerance? I want to make sure the film won’t be damaged by heat or peel off quickly.
Thank you in advance for your insights!
pagodi
21 Jun 2016 15:08
Thank you very much for the very helpful answers so far!
@benonon: It is difficult to determine the exact temperature. These are tealights and occasionally small LED strips with a low heat emission. So the heat source is moderate – I estimate a maximum of 40–50°C (104–122°F) in some spots, but it can occasionally get briefly warmer, for example when several candles are burning.
I wanted to avoid the film discoloring, bubbling, or peeling due to the heat. The material of the KALLAX is also important to me – of course, I don’t want to damage it.
@Muso4: Your assessment is correct; the shelving unit is not designed for extreme heat, but with candles it can get warm over time, and I want to be on the safe side.
Are there specific brands or product types you can recommend that can safely handle these temperature ranges?
Isabel
21 Jun 2016 16:32
Hello pagodi,
for temperatures between 40-50°C (104-122°F), I can recommend vinyl films that are specifically labeled as heat resistant. They adhere well to smooth furniture surfaces such as melamine.
Brands like Oracal or 3M offer such films. Look for product descriptions that mention "heat resistant" or "kitchen grade."
These films are easy to work with and durable.
Good luck!
CHRISTOP33
22 Jun 2016 10:20
pagodi schrieb:
"Are there any specific brands or product types you can recommend that reliably cover these temperature ranges?"
Sure, a good choice is films from Oracal. They have a series 651, which is recommended as weather-resistant and heat-resistant up to about 80°C (175°F). They adhere really well to furniture and are fairly resistant to heat.
One more tip: Make sure to prepare the KALLAX surface thoroughly—clean and grease-free—otherwise the film won’t last long, especially when exposed to heat.
Have fun applying it! 🙂
