ᐅ Are there heat-resistant furniture films to prevent fading on KALLAX units?
Created on: 4 Jul 2023 08:23
Nibau34
Nibau34
4 Jul 2023 08:23
Good morning everyone,
I have the following question: Are there heat-resistant furniture films that specifically protect against fading on a KALLAX shelf from IKEA? I’m looking for films that maintain their color and texture even when exposed to sunlight and higher temperatures, without fading or getting damaged quickly. I want to protect my KALLAX in the living room in a fairly bright spot without completely changing the surface or applying a complicated paint job. Does anyone have experience with such heat-resistant films that also look good? Thanks in advance!
Leote
4 Jul 2023 08:47
I am not aware of any special heat-resistant furniture films for the KALLAX. Usually, manufacturers recommend films only for rooms without direct sunlight. For heat resistance, you should rather look for materials used in the automotive sector.
PULAU
4 Jul 2023 09:15
There are indeed films with heat resistance of up to 80-100 degrees Celsius (176-212 degrees Fahrenheit) that provide UV protection and can slow down fading. It is important to pay close attention to the technical specifications provided by the manufacturer, especially regarding UV resistance and heat tolerance. However, complete protection is difficult under very strong sunlight. A reflective pane in front of the window or a sunshade blind could offer additional help.
elgla
4 Jul 2023 09:48
I’m in a similar situation. A few months ago, I tried covering my KALLAX near the window with a film – unfortunately, despite UV protection, the color eventually changed. That was a bit disappointing, especially since the edges of the shelf faded quite quickly. I would appreciate any tips on how to prevent this in the long term, as I don’t want to move it away completely.
Joshbe
4 Jul 2023 10:12
On the topic: PVC films with UV protection are the most common option. They are heat-resistant up to about 80°C (176°F), but direct sunlight on the films can reduce their protective effect. Alternatively, there are polymer films that are more resistant to UV radiation. In any case, when applying them to furniture with an MDF or particleboard core, proper adhesion and surface preparation are essential to ensure the films are durable.
gesar32
4 Jul 2023 11:03
I would like to add: Furniture films with heat-resistant coatings are often standardized for indoor use but not for continuous exposure to direct sunlight over several hours daily. Depending on the type of film, temperature fluctuations and UV exposure can cause the material to become brittle and lead to color changes. A combination of UV protection window film and heat-resistant furniture film is recommended.
