ᐅ Are there easily replaceable doors available for Billy bookcases?
Created on: 12 Apr 2021 08:42
ENNOLE
ENNOLE
12 Apr 2021 08:42
I am considering upgrading my Billy bookcases with new doors or replacing the existing ones. I have a question: Are there any easily replaceable doors for Billy bookcases from IKEA that can be purchased separately and fit without much hassle? I don’t mean the original doors, but possibly compatible alternatives that can be simply installed and swapped if needed, without having to disassemble the entire bookcase.
It is important to me that the doors match the overall look of the bookcase, both in terms of dimensions and design. Easy installation is also a key factor since I don’t want to do professional-level carpentry work. Does anyone have experience with this or any tips on whether this is even practical? Thanks in advance!
daalessio
12 Apr 2021 10:53
ENNOLE schrieb:
Are there any easily replaceable doors for IKEA Billy shelves that can be purchased without much hassle and fit without major adjustments?
The original Billy doors from IKEA are actually the best fit for the shelves and can be replaced relatively easily because they use hinges that can be mounted directly.
There are third-party alternatives available, but you need to pay close attention to the dimensions and mounting hardware, as many replicas do not fit exactly and often require modifications to the frame or hinges. Unless you have strong DIY skills, I recommend sticking with the original doors.
If you want to replace the doors with glass ones or other types of fronts, you might also need to adjust the hinges or drill new holes. Overall, this is possible, but it is not a plug-and-play solution.
WARREN
12 Apr 2021 14:27
daalessio schrieb:
Original Billy doors from IKEA are best suited to the shelving unit and can be replaced fairly easily
In short: buy original doors and have them fitted. Third-party options are usually too inaccurate.
Installation is simple—just clip the door onto the hinge, and it’s done.
V
vinpau
13 Apr 2021 09:16
ENNOLE schrieb:
Are there any easily replaceable doors for Billy bookcases from IKEA that you can simply buy again?
Oh yes, and it’s really great! 🙂 I recently updated my Billy bookcases with the new doors from IKEA, it’s super easy and looks amazing! Just remove the hinges, attach the new doors – no hassle at all.
WARREN schrieb:
Buy original doors and have them fitted
Exactly! It saves you frustration, and the originals fit perfectly. I highly recommend buying them officially and giving the simple installation a try. It’s fun, and it instantly makes the bookcase look much more modern and stylish. Good luck! :-)
