ᐅ Are there any DIY solutions for floor leveling when installing IKEA PLATSA?
Created on: 18 Feb 2020 08:37
X
xhulio
Hello everyone, I am currently working on a project to install the IKEA Platsa shelving system on a floor with an uneven surface. My question is whether there are any DIY solutions for leveling the floor that are effective and stable without immediately requiring a full subfloor construction or floor replacement. I am especially interested if anyone has successfully used simple methods such as special shims, wedges, leveling mats, or similar tricks. What experiences have you had, particularly regarding the stability and long-term effects of such adjustments?
chenfi
19 Feb 2020 08:05
Opt for combined solutions: use rubber furniture pads plus a thin layer of wood shavings underneath. This provides good grip and compensates well for minor floor irregularities.
feklo
19 Feb 2020 10:42
To add to this, here is a structured suggestion:
- Step 1: Clear the planned area and measure height differences using a long spirit level or a laser level.
- Step 2: Use self-adhesive plastic shims in various thicknesses for minor differences up to 3 mm (0.12 inches).
- Step 3: For larger unevenness exceeding 5 mm (0.20 inches), custom-cut wooden wedges made of plywood are recommended. These can be adjusted precisely.
- Step 4: Secure the wedges to the floor with wood glue to prevent shifting later on.
- Step 5: Assemble the Platsa shelving unit and check its levelness with the spirit level. Fine adjustments are usually necessary.
Common mistakes include using compressible materials or neglecting to secure the wedges. This can cause the shelving unit to wobble or lean. Also, always increase the load gradually to detect any stability issues early.
raelto
20 Feb 2020 09:18
Regardless of any DIY measures, it is important first to objectively assess the general condition of the floor. If the surface has multiple levels or visible damage, temporary leveling measures will be of limited effectiveness.
For floor adjustment with IKEA PLATSA, the following practical steps are recommended:
- Local measurement of height differences using an accurate measuring device
- Use of PVC underlays with a defined thickness beneath the furniture feet
- Securing with solvent-free assembly adhesive that remains reversible
This ensures a stable and durable setup while simultaneously protecting the floor covering. High precision in leveling is essential to avoid stress in the furniture.
X
xhulio
20 Feb 2020 14:55
Thank you for your detailed responses!
In particular, feklo’s remark about securing the wedges really broadened my understanding. I was just wondering whether loose wedges would provide sufficient stability.
KUDAISY schrieb:
Typical mistakes are using shims that are too thick, which compress or shift over time, as well as neglecting moisture development beneath the materials.
I should definitely pay more attention to the moisture issue since the room occasionally has higher humidity levels. Does anyone have recommendations for supporting materials that are particularly resistant to moisture yet not too hard?
Thank you in advance!
Tevin
21 Feb 2020 07:33
Hello xhulio,
You asked about moisture-resistant materials that are not too hard. Good results have been achieved with rubber or EPDM furniture pads, which are water-repellent and elastic. These materials do not swell and remain dimensionally stable for a long time.
As an alternative, high-quality silicone feet also work well; they are flexible, durable, and resistant to moisture. If you use wooden wedges, it is best to paint or impregnate them to prevent swelling.
If you additionally secure the wedges, make sure the adhesive is moisture-resistant so that stability is maintained over time.
I also recommend allowing some air circulation under or around the furniture to prevent moisture buildup.
Nils58
21 Feb 2020 08:48
A quick note about moisture: Some time ago, I started using fine felt pads with a rubber base. They are breathable enough and prevent moisture from accumulating under the shelf. Since then, no more problems—highly recommended, especially with laminate or hardwood floors.
