ᐅ Are there any maintenance products that offer especially good protection for Ikea Hemnes furniture?
Created on: 9 Oct 2020 14:07
marli34Hello everyone, I have a somewhat specific question that might be interesting for those who also own furniture from the Ikea Hemnes series. It concerns the protection of these pieces, especially since they are usually made from solid pine wood, which can be prone to scratches, moisture, or yellowing from UV light.
So my question is: Are there any special care products that, due to their composition or effectiveness, are particularly suitable for protecting Ikea Hemnes furniture from wear, discoloration, or damage? I would like to know which products you have tested yourselves, what experiences you have had, and whether there might also be professional recommendations specifically tailored to the needs of Hemnes furniture.
Thank you in advance for your tips and advice!
Hello marli34, thank you for your detailed and well-structured question! In general, I would say that for caring for Ikea Hemnes furniture made of pine wood, traditional wood care products are quite suitable, but a few details should be kept in mind.
- First, oil-based wax products work particularly well because they nourish the wood surface while also creating a water-repellent layer. It is important to ensure that the wax is not too thick, as this can alter the surface.
- Second, for daily cleaning, a mild, pH-neutral cleaner is recommended. Using harsh cleaners often leads to the loss of the protective layer.
- Third, there are specialized wood protection products that use natural ingredients and include UV protection – this can help prevent discoloration.
I have been using a natural linseed oil product with a UV filter for years, which protects my Hemnes dressers very well and keeps the surface nicely matte. I would be interested to know if others have experience with specific IKEA own-brand products or other brands.
GUSTAVO569 Oct 2020 15:23I would like to get a bit more technical here because protecting Ikea Hemnes furniture, especially when made of pine wood, truly requires a combination of proper preparation and ongoing care.
First, it is important to note that Hemnes furniture is usually sealed with a varnish or a thin protective layer. Before using care products that are oil- or wax-based, you should check whether the surface is still smooth and fully sealed. On a sealed surface, oils often cannot penetrate but instead remain on the surface, which can sometimes cause unwanted stains.
Second, for surfaces that are already worn or slightly roughened, it is advisable to perform an intermediate sanding treatment before applying any nourishing oil. Fine sandpaper (320 grit or finer) can be used to slightly roughen the surface and thereby increase its absorption capacity.
Third:
- For Hemnes furniture with a varnish layer, a special care wax or an oil designed for sealed wood surfaces is recommended.
- For raw pine wood surfaces or oiled furniture, a natural oil such as hard wax oil or linseed oil should be used.
Finally, I would like to ask: Are your furniture pieces currently varnished, oiled, or raw? This significantly affects the choice of products.
Third:
GUSTAVO56 schrieb:
Finally, I would like to know: Are your furniture pieces currently painted, oiled, or unfinished? This significantly affects the choice of products.Thank you for the informative response! As far as I can tell, my Hemnes furniture is coated with a paint that gives the wood its typical white color and slight sheen. It’s not completely matte, but not really glossy either. I had assumed it was covered with a very thin layer of paint, so I have been careful when cleaning to avoid scratching.
Therefore, I am now interested in whether there is a specific type of protection for painted Hemnes furniture that goes beyond regular cleaning with mild detergent, to preserve and protect the paint. I would appreciate any advice on suitable polishes or protective products that can also gently refresh the surface.
I can share from personal experience that protecting painted Hemnes furniture can be quite an emotional matter because the light, cheerful appearance is highly valued, and even the smallest scratch immediately catches your eye. It is important to me not only to clean practically but also to have the feeling that the furniture is well cared for and remains beautiful for a long time.
So far, I have been using a mild furniture wax that is applied very thinly, and it effectively maintains the white paint. It also seals and gives this very thin protective layer a kind of polish.
Maybe this tip can help with your concern as well, because I feel that a proper furniture wax without harsh solvents can definitely help prevent the paint from becoming brittle.
How do you usually handle spilled liquids or minor stains? Sometimes the replaceability of parts at Ikea can be helpful to some extent, but I would like to know if you also pay particular attention to the issue of surface scratches?
Here is a brief, structured guide that I recommend for maintaining Ikea Hemnes furniture with a painted surface:
1. Cleaning:
- Do not use aggressive cleaners.
- Remove dust and dirt with a soft, slightly damp cloth.
- For heavier dirt, use a mild soap solution.
2. Protection:
- Use a water-based furniture polish or a special wax designed for painted surfaces.
- Apply it sparingly and thinly with a soft cloth.
- Avoid using too much product to prevent stains.
3. Damage Prevention:
- Do not use sharp or abrasive sponges.
- Avoid direct sunlight and extreme humidity.
4. Refreshing:
- Repeat maintenance every 6 months.
- Minor scratches can be repaired with a matching paint pen.
Common mistakes:
- Using oils on painted surfaces (often causes unsightly stains).
- Wiping furniture too wet.
- Using care products without consulting the manufacturer.
In summary, I recommend avoiding oils or oil-based waxes on Hemnes painted furniture, and instead using mild furniture wax or polish specifically made for painted surfaces.
1. Cleaning:
2. Protection:
4. Refreshing:
Common mistakes:
