ᐅ Are there any tips or tricks to speed up the assembly of the Ikea BRIMNES furniture?
Created on: 22 Jul 2019 08:23
Eliba
Eliba
22 Jul 2019 08:23
Hello everyone, I am currently facing the task of assembling an Ikea Brimnes furniture item. I would like to know if there are any special tips or procedures to speed up the assembly process without compromising stability or functionality. I have already reviewed the instructions, but some steps seem quite time-consuming, especially when trying to do everything correctly and avoid mistakes. Does anyone have experience with the BRIMNES, particularly with speeding up the assembly? Are there preferred tools, a recommended order for assembly, or other useful advice? I would really appreciate practical tips that make the assembly easier while ensuring the furniture remains stable in the end. Thanks in advance!
Wesley
22 Jul 2019 09:11
Hey Eliba! Great question, since I’ve already assembled the BRIMNES myself. My top tip: Set up a sort of “screw station” first and organize all the small parts by type. This saves a lot of time searching during assembly. I also worked with a cordless drill with torque control – don’t tighten too much, or the material will complain. And yes, a little insider tip: Just before fully tightening, pre-screw all parts lightly. This way, the screws go in faster when you connect everything step by step. Sounds simple, but it really helps. Good luck, and please keep us updated on how it goes!
COLEBAR
22 Jul 2019 09:45
Briefly and clearly: Read the entire assembly manual before starting. Sort all screws and parts by type beforehand. Use a cordless screwdriver. Having an assistant speeds up the process. Keep the assembly area clear.
Neogi
22 Jul 2019 10:17
Interesting point from Wesley regarding pre-drilling lightly, but I wonder whether this really saves time with a piece of furniture like BRIMNES due to the material structure, or if it rather increases the risk of splintering and later stability issues. In general, one should check whether the instructions allow for technical optimizations, or if they have been deliberately designed conservatively and safely to prevent damage. Does anyone have reliable experience regarding the long-term stability of pre-assembled joints?
Genevieve
22 Jul 2019 10:53
[@Neogi, post: y4u6e7, member: XXX]Interesting point from Wesley regarding the slight pre-screwing[/quote]
I would respond to that. Without evidence, such ‘tricks’ initially seem risky to me. In my opinion, the material used in the BRIMNES model is not particularly sturdy, and improper pre-screwing could cause issues. Instead, I would focus more on careful preparation and meticulous work rather than saving time at any cost. Precision is my top priority here.
nera59
22 Jul 2019 11:26
Okay, to organize this clearly, here are some tips from my experience that not only speed up the assembly of the BRIMNES but also make it safer:
- Preparation: Sort all components and fittings before starting to avoid wasting time searching.
- Tools: Use a cordless drill with adjustable torque to prevent damage to the materials.
- Work surface: A clean, level surface ensures precise work and fewer mistakes.
- Step-by-step approach: Tighten connections only enough to hold all parts loosely together at first – then fully tighten afterwards.
- Helper: If possible, have a second person assist with holding and adjusting parts.
These steps may not save minutes at all costs, but they prevent mistakes that would cost much more time to fix later.
