ᐅ Are there any tips for reinforcing Ikea BESTA furniture to handle heavier loads?
Created on: 15 Jul 2015 09:37
tepau
tepau
15 Jul 2015 09:37
I am planning to use some Ikea Besta furniture pieces in my apartment, but I am concerned that they might not hold up well under heavier loads. Specifically, I would like to know if there is any way to prepare these furniture items for higher weight capacities—whether through additional reinforcements, appropriate assembly methods, or special materials.
Does anyone have experience or tips on how to stabilize the BESTA furniture so that it can better support heavier items like books, electronics, or other equipment? What modifications are practical and effective without compromising the appearance and functionality?
I look forward to constructive advice and shared experiences. Thanks in advance!
sarpa
15 Jul 2015 11:05
To improve the load-bearing capacity of Ikea BESTA furniture, I recommend the following measures:
- Use metal brackets at the joints to increase stability.
- Replace the original screws with longer and stronger screws where possible.
- Install additional internal braces or reinforcement strips made of solid wood at the back panel or on the sides.
- Avoid using particleboard back panels; instead, use a plywood panel for better load distribution.
- Carefully assemble and periodically check the brackets to ensure they remain securely fastened.
These tips are effective and do not significantly affect the appearance, but they offer substantial potential for increasing load capacity.
Garth49
16 Jul 2015 17:53
Really interesting, thanks for the question! 😃 I reinforced my BESTA cabinets myself and can confirm that metal brackets especially make a huge difference! I installed them inside the corners, and since then everything has held very securely, even when I place heavy appliances on top.
Additionally, I replaced the back panels with plywood – this simply makes the whole structure much more stable and gives it a higher-quality feel. If you have some basic DIY skills, this is easy to do.
So, go ahead and give it a try, you’ll be really proud of the result! 👍
mipau
17 Jul 2015 08:12
Insert metal brackets,
plywood back panel,
use reinforced screws.
This is sufficient for higher loads.
tangi
17 Jul 2015 22:44
I would like to add that the load capacity depends not only on the reinforcement of the furniture itself but also on proper wall mounting.
Especially for tall BESTA units, it is essential to secure them firmly to the wall using appropriate anchors and screws to prevent tipping or warping. Careful alignment during installation also significantly affects stability.
Additionally, I recommend paying attention to the maximum width of the shelves when they will be heavily loaded, as wider units tend to bend more. If necessary, it is better to place and connect several narrower modules side by side.
