ᐅ Are there any tips for painting Ikea Pax wardrobe doors in custom colors?
Created on: 28 Oct 2023 21:37
IxrironAre there any tips for painting Ikea Pax doors? I plan to redesign my white Pax doors and would like to paint them in a different color to better match my room. However, I’m unsure about the best approach to achieve a smooth and durable finish. I’m especially interested in:
- Which materials (primer, paint type) are recommended?
- Do the doors need to be sanded, or can they be painted directly over?
- Are there specific techniques or tools that help with the smooth surfaces of Pax doors?
- How can drips, bubbles, or scratches be avoided during painting?
I have some DIY experience and basic knowledge, but I want to avoid mistakes that could ruin the result later. I’d appreciate detailed advice and assume some users here have completed similar projects.
Ixriron schrieb:
Are there any tips for painting Ikea Pax doors in different colors? I plan to redesign my white Pax doors and would like to paint them in another color to better match my room. However, I’m unsure about the best approach to achieve an even and durable finish. I’m especially interested in:
- Which materials (primer, type of paint) are recommended?
- Do the doors need to be sanded, or can they be painted over directly?
- Are there special techniques or tools that help with the smooth surfaces of Pax doors?
- How can I avoid runs, bubbles, or scratches during painting?
I have some DIY experience and basic knowledge but want to avoid mistakes that could ruin the final result. I’d appreciate detailed tips and assume that some users here have completed similar projects.
I completely understand how frustrating it can be when you put in effort and the result doesn’t turn out as expected. I also once planned to update my Pax doors and tried several approaches.
Basically, thorough preparation really helps: sanding is almost unavoidable on the smooth surfaces because paint won’t adhere well otherwise. I used fine sandpaper (grit 220) to lightly roughen the surface.
Regarding paint: make sure to use a high-quality acrylic paint suitable for furniture or doors. Water-based paints are often easier to work with, but you should check that the paint is compatible with the door material. Primer is essential; it helps the paint stick better and also protects the doors from moisture.
Tools like a foam paint roller can help achieve a smooth finish — brushes often leave streaks. My mistake was applying paint too thickly, which caused runs. It’s better to apply several thin coats and let each dry in between.
Another tip: paint in a well-ventilated area and lay the doors flat or hang them up to dry so they don’t collect dust during drying.
If you want, I can share more details later about specific types and brands I’ve had good experience with.
Ixriron schrieb:
Are there any tips for painting Ikea Pax doors in different colors? I plan to redesign my white Pax doors by painting them a new color to better match my room. However, I’m not sure about the best approach to achieve an even and durable result. I’m mainly interested in:
- Do the doors need to be sanded, or can they be painted directly over the surface?
- Are there special techniques or tools that help with the smooth surfaces of the Pax doors?
- How can you avoid drips, bubbles, or scratches during painting?
I have some DIY experience and basic knowledge, but I want to avoid mistakes that could ruin the final outcome. I’d appreciate detailed advice and assume some users here have done similar projects.
Ikea Pax doors usually have a melamine or foil coating, which makes the painting process more challenging.
1. Preparation: Sanding is essential to ensure the paint adheres properly. It is recommended to start with sandpaper around 240 grit to lightly roughen the surface without damaging it.
2. Primer: Use a bonding primer designed specifically for smooth and hard-to-paint surfaces, for example, acrylic- or alkyd-based primers.
3. Paint type: A solvent-based 2K acrylic or alkyd paint provides a durable and resilient finish. Water-based paints produce less odor but may be less robust on these substrates.
4. Technique: Use a spray gun or high-quality painting tools to achieve smooth and even coats. If using a brush or roller, apply thin layers and allow them to dry well between coats.
5. Drying conditions: A dust-free, well-ventilated environment is important, with an optimal temperature between about 20-25°C (68-77°F).
6. Finishing: Lightly sand between coats with fine sandpaper (320-400 grit) to prevent visible lines and promote adhesion of subsequent layers.
Following this sequence and using these materials will help achieve a long-lasting and uniform paint finish.
Elias schrieb:
I worked with fine sandpaper (grit 220) back then to lightly roughen the surface.That is actually the crucial point. The surface is often underestimated – Ikea uses inexpensive veneers on Pax, which simply don’t provide a good base for adhesion.
RENMA schrieb:
Use a spray gun or high-quality painting tools to ensure smooth and even coats.Honestly: For DIYers, a spray gun is often not an option. The equipment is costly and requires practice. Anyone trying to use a roller or brush risks making mistakes.
My advice: If you don’t want to do it professionally, it’s better to go with matte spray paints as a compromise – it won’t look perfect, but sanding and brushing can also go wrong quickly.
Also, I wonder if this ultimately comes down to cost and time. It might be better to choose the doors directly from Ikea in the desired color or go for a wrap instead – then you can avoid painting marathons altogether.
I tend to be pragmatic about this: Perfectly painting Pax doors is more of a passion project for hobbyists with time and patience. Anyone attempting it without professional equipment should expect to do touch-ups.
