ᐅ Do you have any tips for maintaining Ikea Hemnes furniture in homes with children?
Created on: 24 Jun 2023 13:27
klalazaroK
klalazaro24 Jun 2023 13:27Hello everyone,
I am currently looking for practical tips and advice on caring for furniture from the Ikea Hemnes series, especially when used in homes with children. The surfaces are usually painted or waxed, and I’m wondering which maintenance methods are effective to keep the furniture in good condition for as long as possible despite frequent use and the typical small accidents that happen with kids.
What cleaning products would you recommend? What approaches have proven successful for dealing with stains or scratches? I’m also interested in whether there are any special treatments that protect the surface without causing damage or darkening it.
Do you have any advice on how to prevent damage, for example with protective films or certain handling practices? What are your experiences with daily use of Hemnes furniture in children’s rooms or common living areas? I’m looking forward to well-informed tips and insights!
Thank you in advance!
Hello klalazaro,
Regarding your question: Caring for Ikea Hemnes furniture, especially with children, does require some attention, as the painted or waxed wood surfaces can be sensitive.
Here is a brief overview:
- Cleaning: It is best to use a damp, well-wrung cloth with a mild soapy solution (such as diluted dishwashing liquid in water). Avoid abrasive cleaners and harsh chemicals.
- Stain Removal: For sticky stains, a gentle approach with mild rubbing alcohol on a soft cloth is recommended, but you should test on an inconspicuous area first to prevent discoloration.
- Scratches: Small scratches can be repaired using special wood repair markers in a matching color. Otherwise, furniture wax or polish designed for painted or waxed surfaces can be helpful.
- Protection: Simple protective measures include felt pads under items that are frequently moved, as well as coasters for glasses or other liquids.
In summary: Use minimal water, avoid harsh cleaning products, and encourage children to handle the furniture carefully.
If you like, I can also provide a detailed step-by-step care guide.
Hello klalazaro,
your question about caring for Ikea Hemnes furniture in a household with children is very relevant, as the combination of child-friendly use and wooden furniture with treated surfaces poses specific challenges. Below, I will explain the key points in detail:
1. Surface finish:
The Hemnes series primarily features white lacquered wooden surfaces. This lacquer has a satin-matte sealed finish, which provides some resistance to impacts and moisture but is not indestructible.
2. Cleaning:
- Regular wiping with a slightly damp microfiber cloth is recommended.
- Avoid harsh cleaning agents like ammonia or alcohol, as these can damage the protective layer.
- For tougher dirt, pH-neutral cleaners are advisable, such as neutral furniture cleaners.
3. Stains and stain removal:
- For sticky residues, some parents use a cloth dampened with lukewarm soapy water.
- Dried stains should be soaked first and then gently wiped off.
4. Protection and prevention:
- Especially with children, I recommend using throws or transparent protective films on frequently used surfaces. However, it is important to ensure breathability to prevent moisture buildup.
- Using coasters, felt pads, and avoiding heavy or sharp toys on the furniture are also sensible precautions.
- Daily reminders to handle the furniture carefully are more effective than any protective measure alone.
5. Repairing minor damage:
- Wood repair kits with wax or colored sticks work well but are not a permanent solution for deeper scratches.
- Treating individual spots with furniture wax can help refresh the surface.
I am interested to hear about any specific problems or damage you have noticed on your Hemnes furniture so far. This will allow for more targeted care advice.
1. Surface finish:
2. Cleaning:
klalazaro25 Jun 2023 12:44Gafiel schrieb:
I am interested in what specific problems or damages you have experienced so far with your Hemnes furniture? This would help provide more targeted care advice.Thank you for the detailed response. So far, it has mainly been minor scratches and wear on the table edges, as well as some stains from spilled drinks on the dresser. The children are still quite young (3 and 5 years), so sticky or damp fingers on the surfaces are quite common.
In daily life, I try to enforce regular wiping down, but of course, it’s not always easy to clean everything immediately.
I find your point about protective films and covers interesting. So far, I have been hesitant because I worry that moisture or dirt could build up underneath. How can moisture buildup be effectively prevented in these cases? Are there any recommended materials or products that have proven especially effective for Hemnes furniture in homes with children?
