ᐅ Are there any tips for quickly assembling the Ikea BRIMNES?
Created on: 25 Nov 2020 09:17
Tau-se
Hello everyone, I’m planning to get the Ikea Brimnes system, but I want to assemble it as quickly and efficiently as possible. Are there any users here with experience in fast assembly of this furniture? I’m specifically looking for tips on preparation, tools to have ready, or tricks that significantly reduce the assembly time. My main goal is to avoid common pitfalls to make the process smooth and time-saving. Thanks in advance!
Gilbert
25 Nov 2020 13:05
I wonder if the general strategy of "start loose, then tighten" is overkill for such a simple piece of furniture. Ikea designed the parts to be assembled quite easily. Or are you overestimating the difficulty? Maybe the problem isn’t with the assembly itself but rather with the preparation or mindset?
flota
25 Nov 2020 13:32
Gilbert schrieb:
Maybe the issue isn’t in the assembly itself, but rather in the preparation or mindset?
This perspective is certainly valid. Preparation—that is, carefully sorting and reviewing the parts as well as understanding the instructions—is crucial for a fast and smooth process. However, the attitude should not be underestimated. Rushing often leads to mistakes. The principle “loose before tight” is therefore not overcautiousness but a practical workaround to avoid rework.
Tau-se
26 Nov 2020 08:21
I share the same view as flota. Especially with Brimnes, I also have the impression that the fit is very precise, but the various components and drawer slides require a certain adjustment period. I would like to know if there are any specific tips for the drawer slides or door hinges to avoid installation errors. Any ideas?
Jeanbar
26 Nov 2020 09:03
Regarding the drawer slides: The mechanism is usually a bit tricky. My tip is to lightly oil the slides on both sides before installation (for example, a drop of silicone oil) and to make sure they are inserted fully and parallel. This helps prevent jamming later. It also helps to assemble the parts on a table first and test their movement before attaching them to the furniture. For the door hinges, it is advisable to attach them loosely at first so the doors can be finely adjusted – small adjustment screws on the hinges often help with this.
paulu
26 Nov 2020 10:17
Summary: - Sort the parts - Use a cordless screwdriver - Screw in the screws loosely at first - Lightly oil the drawer slides - Attach doors loosely for fine adjustment only
Danial
26 Nov 2020 11:29
Interesting discussion here, but perhaps we should also consider whether the rush during the installation of self-build systems like BRIMNES might reflect a broader issue in today’s consumer society: always faster, despite lacking skills. I would recommend using installation time as a quality margin rather than just a tedious obligation, to ultimately minimize mistakes and frustration. This may sound less helpful for quick assembly, but a deliberate, calm approach provides long-term benefits.
