ᐅ Are there any special considerations when assembling Ikea Hemnes furniture in damp or humid rooms?
Created on: 17 Feb 2023 08:37
MOIRAHello everyone,
I am currently planning to install several Hemnes furniture pieces from IKEA in a damp room, specifically a basement room that occasionally experiences higher humidity levels. My question is whether there are any special considerations when assembling this series in such environments.
Are there specific methods or steps to protect the furniture from moisture damage? Should different materials or screws be used during installation, or does IKEA already provide moisture-resistant features for Hemnes as standard?
I am also interested in any long-term experiences you might have—how well do the furniture hold up in these rooms over time, and are there any preventive measures to increase their durability?
I would greatly appreciate any answers, especially those that include specific construction tips or care advice!
Hello Moira,
your question is very valid, as the Hemnes style from IKEA is, as you probably know, mainly made from solid wood. Solid wood is naturally more susceptible to moisture compared to coated particleboard or MDF.
When assembling in damp areas like your basement, you should keep a few points in mind:
- Ensure sufficient ventilation in the room so that no permanent moisture remains on the furniture.
- Do not use wet cloths to clean the components before or during assembly.
- It can be helpful to treat all parts with a wood preservative or special impregnation before assembly. This can improve protection against moisture penetration.
- Avoid placing the furniture directly on the floor if it is very damp. Use furniture glides or small pads to allow air circulation.
IKEA itself usually does not explicitly mention special measures for damp locations in their assembly instructions, but practical tips like these can help prevent damage.
Long-term experience shows that Hemnes, with proper care, can last several years even in moist environments, but not indefinitely. Moisture can cause wood to swell and create bubbles or cracks.
I hope this helps you!
Additional information:
The IKEA Hemnes furniture is mostly made of solid pine wood, which is durable but not specifically treated for damp environments. Here are some facts and practical advice:
- The wood is untreated or at most white-lacquered, which does not provide waterproof protection.
- A humid environment increases the risk of swelling, which can lead to warping or cracking.
- Assembly is done with barrel nuts, screws, and dowels that are corrosion-resistant – however, your options for modification are limited.
Therefore, I recommend:
- After assembly, make sure to seal all visible edges and panels with clear varnish or another type of wood protectant.
- Avoid direct water splashes; ideally, place the furniture away from showers or washing machines.
- If possible, equip the basement or room with a dehumidifier.
This way, you can prevent damage in advance. Additionally, the furniture should be checked for signs of moisture at least every few months to catch any issues early.
In summary: IKEA does not offer a moisture-resistant version of Hemnes. You will need to compensate for this yourself.
sarlo schrieb:
It can be helpful to treat all individual parts with a wood preservative or a special impregnation before assembly.This is a crucial point I would like to emphasize. Hemnes is solid wood, but that also carries risks in damp environments. The question here is which wood protection you use and how it affects the natural appearance.
Furthermore, I want to point out critically that Hemnes is not a furniture line designed for humid rooms. Even with protective measures, wood absorbs moisture if the surrounding conditions remain consistently high – the issue then is not the assembly itself, but the material in general.
A possible alternative would be if IKEA or other manufacturers offer furniture made of MDF or multiplex with moisture-resistant coating. These are more durable due to their finish.
So, if you decide on Hemnes, you should be realistic about its lifespan. Technically, no changes are needed during assembly, but that doesn’t mean you shouldn’t apply additional protective layers.
What is the average humidity level in your basement? That can significantly affect the assessment.
farje schrieb:
What is the average humidity level in your basement? That can significantly affect the assessment.Good question, thanks for asking! The humidity in the basement varies between 65% and 80% relative humidity, with levels occasionally rising, especially in winter. It’s not a permanently damp room, but increased moisture over longer periods is definitely present.
It’s important to me that I can use the furniture sustainably, not just store it temporarily. That’s why, in addition to the recommendations mentioned earlier, I will probably look for a suitable wood preservative.
Are there any recommendations for wood protection products that work well and do not affect the appearance of Hemnes furniture (usually painted white)? Also, is it better to apply the protection before assembling the furniture or after construction?
MOIRA schrieb:
Are there any recommendations here for wood preservatives that work well without affecting the appearance of Hemnes furniture (mostly white lacquered)?Since Hemnes furniture is painted or stained white, protecting it without altering the surface appearance can be a bit tricky. Ideally, before assembling the furniture, you can treat the edges and backsides with a water-repellent wood preservative oil or a clear water-based varnish. These products usually penetrate invisibly and hardly change the surface.
If the furniture is already assembled, it is still possible to apply wood preservatives using a fine brush or sponge—especially on joints and edges where the wood is most vulnerable.
Important: Always test the product first on an inconspicuous area to ensure the appearance is not affected.
From personal experience, a product that includes fungicide and insect protection is recommended, even if moisture is the main concern. It also helps prevent mold growth in the wood.
In summary:
- Treat parts before assembly if possible and advisable
- Apply touch-ups on hard-to-reach edges after assembly
- Prefer cleaning with dry cloths, always avoid moisture
This approach should help you keep Hemnes furniture more stable and durable when stored in a damp basement.
