ᐅ Are there alternative mounting options for Ikea Pax wardrobes?
Created on: 8 Mar 2023 10:17
EdsonpauHello everyone,
I have a question regarding mounting options for Ikea Pax wardrobes. Specifically, I’m interested in whether there are alternative methods to securely fix these wardrobes without using the standard Ikea mounting kits. I plan to install a Pax wardrobe on a wall, but for various reasons (such as special wall materials or aesthetic considerations), I would like to avoid the usual angle brackets and wall plugs.
So my question is: What alternative fastening methods are available for Ikea Pax wardrobes to ensure they are stable and secure on different types of walls? Are there proven solutions using wood, metal, or other materials that might even offer advantages over the original mounting?
I look forward to your experiences and tips. Please also include advice on necessary tools or possible risks with alternative methods.
Hello Edsonpau,
First of all, a very well-formulated and precise inquiry! Your request for alternative mounting options for Ikea Pax wardrobes on different wall materials can be clearly differentiated.
Basically, Pax wardrobes are usually mounted to the wall using the supplied metal brackets, which are typically screwed into solid walls with standard anchors and screws. Variations depend heavily on the wall material—whether drywall (plasterboard), concrete, wood, or a lightweight partition wall.
For drywall, I would recommend using special toggle anchors or so-called "molly bolts" as the type of anchor. These distribute the load better and increase stability.
Alternatively, there are options to use heavy-duty anchors, which provide excellent grip in concrete or brick and are better suited for higher loads. If the wall is really complicated, you could also consider constructing an additional wooden framework in front of the wall and attaching the wardrobes to it; this ensures safer load distribution and also allows for screwing in from the inside.
Another alternative approach is to use tension rods that are stretched from floor to ceiling, similar to some bookcases—this eliminates wall mounting entirely but requires precise adjustment.
For floor anchoring, screwing through the baseboard is also an option. For all alternatives, it is important to calculate the load and observe safety regulations.
What exact wall materials do you have? And how heavy or large is the Pax wardrobe? The more information you provide, the more specifically we can address the best alternatives.
Domau0 schrieb:
What wall materials do you have exactly? And how heavy or large is the Pax wardrobe?This is an important point that should always be clarified first in such cases. The type of fixing largely depends on it, as using the wrong anchor or fixing in the wrong place can compromise the wardrobe’s stability.
In addition to the wall, the floor structure should also be checked if you are considering an alternative floor construction. Especially for heavy wardrobes, I recommend securing them with floor fastenings.
As an additional tip: make sure that alternative brackets can withstand not only static but also dynamic loads, such as the repeated opening and closing of the doors. Some options made of wood or metal therefore require more careful planning and possibly greater precision during installation.
Edsonpau schrieb:
What alternative mounting methods are recommended for securing Ikea Pax cabinets safely and firmly to various wall types?In response to your question: Besides the alternatives already mentioned (heavy-duty anchors, subframe, tension rods), there are also bracket or rail systems that allow direct attachment to both floor and ceiling.
Some users modify the inside of the cabinet carcass with brackets and screws to better distribute the load. Increasing the height of the plinth and adding extra bracing can also improve stability.
However, I would generally advise against completely deviating from Ikea’s safety guidelines, as tip-over safety is especially important for tall cabinets. Therefore, I recommend carefully planning any alternative mounting method in advance and consulting a professional if you are uncertain.
