ᐅ Are scratches on KALLAX surfaces really impossible to repair?
Created on: 20 Sep 2018 18:07
Nape2
Nape2
20 Sep 2018 18:07
I would like to start a discussion on the topic: "Are scratches on KALLAX surfaces really irreparable?"
I have noticed that especially on the white or open surfaces of this popular IKEA series, scratches can appear quite quickly, particularly from everyday use like moving items or cleaning. However, I often read that the surfaces are quite durable, and some even claim that minor scratches can be fixed using specially recommended repair methods or home remedies such as furniture polish, margarine, or special pens.
I am especially interested in experiences with the actual repairability of scratches on KALLAX surfaces: Are smaller or even deeper scratches truly permanent, or are there practical methods to make them almost invisible? And if so, which techniques work reliably without significantly affecting the overall appearance?
I appreciate all tips, assessments, or differing opinions!
Muso4
20 Sep 2018 18:19
Nape2 schrieb:
I am mostly interested in experiences regarding the actual repairability of scratches on KALLAX surfaces.
This is such a typical question where you might almost say: What if we just accept that scratches are part of it? I mean, KALLAX is an affordable piece of furniture designed for everyday use, not for perfectionists wearing white gloves.
Of course, there are ways to somehow paint over or polish out such scratches, but does anyone really believe that can ever be a real solution? Scratches are signs of wear and real use, and trying to hide them often only leads to stains or uneven spots that stand out more than the scratch itself.
Nape2 schrieb:
Are smaller or even deeper scratches really permanent, or are there practical methods to make them nearly invisible?
From practical experience: no. A permanent scratch remains permanent. If you want something that stays beautiful forever, you should probably invest in higher-quality finishes.
bente
20 Sep 2018 18:48
I completely understand the concern about scratches—especially when you put effort into making your home look nice.
Muso4 schrieb:
Scratches are signs of use and real-life wear
That’s certainly true, but for some people, it’s not an easy thought to accept. Especially with a piece of furniture like KALLAX, which is used as a versatile companion in the living room or workspace, visible scratches can quickly affect the overall appearance.
I’ve tried treating minor scratches myself with furniture wax and polish, which improved the look a little. For deeper scratches, as far as I know, it’s hard to achieve a completely smooth repair, but with patience and the right products, the damage can often be visually minimized.
How do you handle scratches when they appear? Do you simply accept them, try to repair them, or replace the item right away? In my opinion, a repair can at least help until a long-term solution is found.
Katau
21 Sep 2018 08:05
I would like to share some basic information that might help those who are wondering how to treat scratches on KALLAX surfaces.
First of all: The surfaces are made of melamine resin-coated particleboard. These are relatively durable, but once the paint or coating is damaged, the underlying particleboard becomes visible, which causes the visual defect.
Minor surface scratches can often be concealed with special furniture repair kits or touch-up markers that are color-matched. It is important to proceed by cleaning and drying the area to be treated before carefully applying the repair material. A follow-up treatment with clear lacquer can provide additional protection.
For deeper scratches or abrasions, it is very difficult to achieve complete invisibility since the material itself is damaged and the structure as well as the color cannot be fully restored.
bente schrieb:
With some patience and suitable materials, the damage can often be visually minimized
I fully agree with this. It is important to have realistic expectations: repair often does not mean a 100% recovery of the original appearance, but a significant improvement is possible.
If desired, I am happy to provide tips on suitable products and techniques.
Ryder35
21 Sep 2018 09:17
Katau schrieb:
Minor surface scratches can often be concealed using special furniture repair kits or touch-up pens
Exactly, for most everyday scratches on KALLAX, a repair kit from a hardware store or online usually helps.
For deeper scratches, replacing the panel is often the only solution, or furniture glue if something is lifting.
Polish or home remedies usually only provide a temporary effect.
