ᐅ Are IKEA PLATSA units suitable for use in bathrooms?
Created on: 2 Jan 2019 08:23
DANCARTER
DANCARTER
2 Jan 2019 08:23
I am currently planning the renovation of my bathroom and am considering using furniture from the IKEA Platsa system. I am especially interested in whether this furniture is suitable for use in a damp room like a bathroom, given its materials and construction.
Specifically, I am wondering:
- Are the Platsa cabinets and their coatings sufficiently moisture-resistant to prevent long-term mold growth or material warping?
- How durable are the connectors and fittings in a high-humidity environment?
- Are there any experiences with special surface treatments or additional protective measures that should be applied to extend the furniture’s lifespan?
I would greatly appreciate any feedback, recommendations, or advice on potential issues. Thank you in advance!
Luchen
2 Jan 2019 10:52
PLATSA is generally not designed for bathrooms because the furniture is mainly made of particleboard.
Moisture can cause the boards to warp or swell.
If you still want to use it, you should ensure good ventilation and avoid direct exposure to water on the furniture.
relupa
2 Jan 2019 14:37
I can understand wanting a practical and flexible solution for your bathroom with IKEA PLATSA furniture. I felt the same way and was unsure how well they would hold up in such a humid environment.
My experience: I installed the furniture in a small guest bathroom that often gets humid after showers. At first, everything seemed fine, but after about a year and a half, small swelling started to appear on the edges. Honestly, I was a bit disappointed because I was quite happy with the appearance and the modular system.
I then treated the furniture with a clear moisture-resistant protective varnish. This helped reduce the swelling, but in my opinion, there is no guaranteed protection. If you decide to go for it, take your time with a good surface treatment and maintain the furniture regularly.
I’m curious if anyone else here has had similar experiences?
Je_nau58
3 Jan 2019 09:16
relupa schrieb:
I then treated the furniture with a transparent moisture-protective varnish.
This is an important point I want to emphasize here. IKEA PLATSA furniture is made from coated chipboard, whose surface film provides some moisture resistance. However, this is not completely waterproof.
With regular and high humidity in the room, moisture can penetrate through the cut edges and joints, causing swelling and failure of the fasteners.
Therefore, my recommendations for bathroom use are:
- Use only in well-ventilated areas that are not directly exposed to water
- Apply additional protection with varnish or water-repellent coating to all edges and visible cuts
- Regularly check for early signs of moisture damage
- Prefer alternative materials such as MDF with waterproof paint or solid wood for wet areas
Without these measures, long-term use in wet areas is risky and potentially problematic.
Teonon
4 Jan 2019 18:42
Je_nau58 schrieb:
Use only in well-ventilated areas that do not get directly wet
Absolutely correct! Last year, I furnished my smaller bathroom with PLATSA furniture and made sure they are not placed directly inside the shower or next to the washing machine.
With additional waterproofing treatment and a dehumidifier in the bathroom, I haven’t encountered any problems so far.
I find the system very flexible and stylistically quite modern – as long as you take the right precautions and carefully plan where to use it.
So yes, IKEA PLATSA furniture can work in the bathroom if properly protected and maintained! Keep it up, and they will last longer than expected.
