ᐅ March 16, 2016: Start of Photovoltaic System Installation
Created on: 16 Mar 2016 10:51
T21150
Today at 10:00 AM, the installation of our new photovoltaic system began.
The approval from the city was granted last week.
Currently, the substructure (Schletter) is being installed.
Tomorrow, the panels will be mounted and the strings routed into the house.
Further electrical installation / inverter setup has not yet been scheduled.
I will keep you updated.
This is an info thread to show how long this process takes, from the first bracket on the roof to commissioning.
Thorsten
T21150
21 Apr 2016 08:03
These are the values from midnight last night until now.
Daily consumption: 2373 Wh
Grid consumption: 933 Wh
Self-supply: 1440 Wh
Battery discharge: 1057 Wh
Direct consumption: 383 Wh
Daily yield: 669 Wh
Self-consumption: 499 Wh
Battery charge: 116 Wh
Grid feed-in: 170 Wh
Autonomy rate: 61 %
Self-consumption rate: 75 %
Direct consumption rate: 57 %
toxicmolotof
21 Apr 2016 13:45
b54 schrieb:
So would you say it is sufficient? For calculating self-consumption, etc.? I’m considering whether I need a logger for my photovoltaic system. It looks like it will probably be Winaico modules with a Fronius inverter.
What do you need a logger for?
The Fronius inverter, together with an additional S0 meter, can log enough data.
T21150
25 Apr 2016 20:24
After exactly one week—mixed with sun, rain, snow, and hail—the situation looks quite interesting, although not representative. The difference between the battery charge and consumption also includes the initial charging of the completely empty battery at startup. In other words, the small battery has covered nearly 2 days’ worth of consumption just from one charge. In my system, the charging/discharging losses are only 3%, which is very low. Larger batteries typically have losses of about 6-8%.
Today, there was almost nothing: here in NRW, the weather has been dreadful... really dreadful. The battery is already “used up” (literally).
But personally, I am very satisfied with the data—I expected less...
PS: Below it says “Monthly consumption.” Of course, it is only exactly one week in this month, as the S0 logger has not been running any longer yet.
Thorsten
Monthly consumption 67.45 kWh
Grid consumption 11.56 kWh
Self-consumption 55.89 kWh
Battery discharge 18.81 kWh
Direct consumption 37.08 kWh
Monthly generation 183.60 kWh
Self-consumption 58.29 kWh
Battery charge 21.21 kWh
Grid feed-in 125.31 kWh
Self-sufficiency rate 83 %
Self-consumption rate 32 %
Direct consumption rate 20 %
T21150
25 Apr 2016 20:39
PPS: The main constant energy drain is the fridge from way back.
370 kWh per year (measured). Totally insane. Modern units use 70–90 kWh/year (measured).
You could maybe accept that—if the appliance still cooled properly. But it doesn’t anymore.
To put it into perspective: This old wannabe cooler consumes over 10% of my total annual electricity usage. Truly remarkable.
Decision made today: The old fridge is retiring.
It will soon be replaced by a newer A+++ rated fridge.
Musketier25 Apr 2016 20:59
That’s not €60. The refrigerator would have to run for 10 years before buying a new one would be worthwhile.
Sebastian79
25 Apr 2016 21:57
My refrigerator is almost new and consumes just under 400 kWh per year—it’s expected since it needs to fit a lot inside 😀
