ᐅ Concealed fittings for bathtub with handheld showerhead
Created on: 20 Mar 2015 14:46
willWohnen
willWohnen
20 Mar 2015 14:46
I’m not clear about the options for the fittings on our future bathtub.
The water should flow into the tub via the fill/overflow button, no faucet. So, an underfloor installation, as far as I understand.
There should also be a thermostat installed under the wall. So I need a control for the temperature. Okay.
Now, the water should sometimes flow into the tub and sometimes to the hand shower. Here is where my "problem" starts.
I definitely don’t want a pull knob for switching.
I have already seen fittings with a rotary control: center position means no water, turning left gradually increases water flow into the tub, turning right gradually increases flow to the hand shower. That’s better than the pull knob, but still not perfect.
We currently have a control like that, and it often causes dripping from the shower or faucet after using the tub, because you would have to position the control exactly in the middle and it’s easy to "overturn" it.
Are there other options?
(My online search hasn’t helped so far. It’s always difficult when looking for unknown variants without the right keywords.)
willWohnen
EveundGerd20 Mar 2015 21:42
I only know the pull-button type and would honestly advise against it.
wrobel27 Mar 2015 07:03
Hello
from Hansgrohe ShowerSelect.
They use push buttons and can control up to 3 outlets.
Brand new and seen at ISH with an integrated hose connection and shower holder as well.
Olli
Kikolool
27 Mar 2015 11:51
We had a similar problem: bathtub rim faucet.
We now have the three-hole version of the Vigour Cosima (not sure if I’m allowed to share the link?), with the spout going directly into the tub:
1) Hose for the hand shower
2) Mixer (hot/cold) and flow control. It looks like a standard single-lever mixer.
3) Rotary knob to switch between shower and tub. I think turning left = shower, turning right = tub. There are only two positions, no in-between.
Alex
wrobel29 Mar 2015 22:22
Kikolool schrieb:
We had a similar issue: bathtub rim faucet.
We are now using the three-hole version Vigour Cosima (not sure if I’m allowed to share the link?), with the spout directly into the tub:
2) Mixer (hot/cold) and flow volume. Looks like a standard single-lever mixer.
3) Rotary knob for switching between shower/tub. I believe turning left = shower, turning right = tub. There are only two positions, no in-between.
Alex
this exact version was precisely what the original poster did NOT want.
Olli
milkie
29 Mar 2015 23:30
We are getting the Grohtherm 3000 UP thermostat with diverter from Grohe. However, to be honest, I have no idea how the diverter works here. Does anyone know?
